Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 03-11-2008, 12:20 PM
Stan is on a distinguished road
Question Gas spring force, series vs parallel
While CNCing my X3, I'm considering putting a counterweight on the Z axis. In particular my thought was to use two gas springs in an offset, compound fashion. The combined stroke length will allow me to offset the weight of the head but not loose any Z travel.
My question is this: Are gas springs arranged in serial additive? If I use two 50 lb units, will I equal 100 lbs of total force?
TIA!
Old 03-11-2008, 12:41 PM
Serial connection you get same force but the travels add.
Parallel you get same travel at twice the force.
Old 03-12-2008, 12:42 PM
Moderator
JerryFlyGuy is on a distinguished road
There was some discussion on this on the Mach3 yahoo list last week.
I've designed a extended travel system using pulley blocks [block/tackle] but in reverse. If you put the gas shock between the two pulleys in the system you need twice the force but only 1/2 the travel [or 3x the force but 1/3 the travel, depending on how many turns in the block system you use].
There are lots of high force gas shocks out there. I plan on using a 300lb one on my Z axis and it will only need to be 8" extended to work w/ a z axis which travels nearly 24".
Food for thought..
Jerry
JerryFlyGuy
The more I know... the more I realize I don't
Old 03-12-2008, 03:52 PM
svenakela is on a distinguished road
Naah, hold on... Serial connection should give twice the travel but half the force. Even though we're talking gas springs, the should follow Hookes law.
Old 03-12-2008, 03:58 PM
Moderator
Sven, are you sure.. I think that a series connection would double the travel at the same force while parrallel would double the force.. Hooks applies to deformation of a material, we're talking about the compression of a gas..
Jerry
JerryFlyGuy
Old 03-12-2008, 03:59 PM
Forget it, I was thinking wrong...
Serial connection is double travel at same force. Geof is soo right.
Old 03-12-2008, 04:04 PM
Jerry
I was not correct. But I was quick posting though!
Hookes law is not about persistant deformation, when a spring is stretched above its limit Hookes is not valid any longer. Hookes is always used when calculating springs. Gas springs will act the same way.
Old 03-12-2008, 08:17 PM
Thanks for the comments guys...
After hearing some feedback elsewhere from some fellow X3 CNCers, I've decided to hold off on the gas springs until necessary. I will design my system to accommodate the gas springs but will only apply them if necessary. I guess there is enough friction in the Z axis that back driving is not an issue. And with the mechanical advantage of the ball screw, at a 2:1 pulley reduction ratio, my 270 oz-in stepper will be OK.
Thanks again!
Old 03-13-2008, 01:21 AM
If they are GAS springs surely it would be Boyles' Law.
Old 03-13-2008, 03:56 AM
Yes, that's true. When it comes to estimating the size of gas springs and as long as the gas is constant in temperature, Hookes is working too. Both gas and metallic springs acts the same way. As long as they stay in temperature, that is.
Calculation Of Force In Order To Select Correct Spring weaston Mechanical Calculations/Engineering Design 2 08-24-2011 08:48 AM
Newbie- What to do? Parallel/Series maintenancemike Stepper Motors and Drives 13 02-09-2008 09:47 AM
Constant Force Spring for Counter Balance biomed_eng DIY-CNC Router Table Machines 2 10-25-2006 09:10 AM
How to make a Constant Force Spring jwvica01 Benchtop Machines 0 06-27-2005 07:17 PM
series or parallel turmite General Electronics Discussion 5 12-28-2003 10:27 PM
