Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 03-10-2008, 10:33 PM
dnunner is on a distinguished road
Ball Screw Errors
I have a question re: ballscrew errors. I purchased two 5tpi ball screws and nuts for my new X and Y axis. I would expect that to move the nut 1 inch they would have to turn 5 revolutions. That would translate to 5 times 200 or 1000 steps per inch. I have a Xylotex drive set to microstep 1/8 so now need 8000 steps per inch. I have used a digital caliper, a 1/2/3 block with a dial gauge and find that if I move 3 inches the actual move is only 2.95 inches which requires that I need to provide approx 8130 steps from Mach 3 to move the full 3.0 inches. Both the X and Y axis are the same. I can only guess that these fairly expensive ground ball screws are not exactly 5tpi. Is this common or am I doing something wrong? Any answers would be appreciated. Dnunner
Old 03-11-2008, 09:33 AM
neilw20's Avatar
neilw20 is on a distinguished road
Smile Try Screw Mapping.
Mach3 can do Screw Mapping. This may solve your problem.
Measure it over 6" and see if you get 5.9". Is it a scaling problem or a linearity problem?
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Old 03-12-2008, 02:28 AM
Zappautomation is on a distinguished road
Just to check the screws, manually turn them ten turns and measure the distance.
Zapp Automation Ltd
www.slidesandballscrews.com
Old 03-13-2008, 11:09 PM
I have fixed the problem, an easy fix when I found out that the ball screws were not 5 TPI at all but 5 mm. dnunner
what bearing fit with acme screw 1/2 -10(for cheap ball screw) apex Linear and Rotary Motion 4 07-27-2007 11:15 AM
roller screw versus ball screw. Paraprop Linear and Rotary Motion 2 04-15-2007 04:21 AM
Belt vrs. Ball Screw vrs. Lead Screw stevesplanes Linear and Rotary Motion 7 01-09-2006 11:23 AM
New technology.... old debate.....ball screw vs lead screw trubleshtr Linear and Rotary Motion 1 08-15-2005 08:42 PM
acme screw to ball screw question Billw DIY-CNC Router Table Machines 9 07-18-2005 12:10 AM
