| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
I've been lurking here for a while. I'm in the process of gathering materials for a DIY CNC router table. (Note, this is a repost from the DIY Router forum. I posted there, but I think I was asking this question in the wrong place. Mods - Feel free to delete the other thread) I've looked at a lot of threads about the ball screws and nuts available from Roton and they definately look like they will do the job for me. My problem is that I have no access to a decent lathe to do the end machining for the screws. Is there a poor man's alternative to properly do end supports for the ball screws and mount a motor, or do I need to save my pennies and go the homeshopcnc.com avenue and get it done for me? I don't have any pre-concieved design for the end supports, so I'm wide open as far as suggestions are concerned. FYI - Backlash is my main concern. I'm looking at doing detail work on prototype materials such as machinable plastics and/or machinable wax. |
| You can by support blocks from a lot of places, http://www.misumiusa.com/ is probably the cheapest you'll find. You said that backlash is your primary concern. Imo mounting the screw without backlash should be relatively easy. You'll have a much more difficult time removing backlash from the ballnut, unless you'll be using double nuts.
| Your best bet is to find a new friend with the machine tools you need to get this done. I'd bet there's someone fairly close that would be glad to help. Maybe post your locale with a question about who could give you a hand? While I would help, I'm in Alabama, not Maryland. I'm also no machinist, though I have some of the tools to be one. ![]() Also be aware that one end of the screw(s) Roton ships is possibly (probably?) annealed for a short distance already. Look for a slightly brighter area at one end. The rest seems to be through hardened and not just case hardened. If I had known this initially, I would have ordered mine as three pieces, not just two with one to be cut into two. But the annealed length was pretty short on mine. I just ground the hard end into a nose (turned the softer ones) and made a stub shaft with the necessary bearing fits and threads and shrink fitted it on. This way, if I "screwed" up I could make a new end out of cheap cold rolled instead of buying a new screw. |
| Ball screws, Acme screws, threaded rod | DJ Morrow | DIY-CNC Router Table Machines | 11 | 03-22-2007 12:39 PM |
| How to support Lead screws | Hacksaw | Mechanical Calculations/Engineering Design | 19 | 01-24-2007 06:52 PM |
| How to support long lead screws....a solution | spunky1974 | Linear and Rotary Motion | 0 | 11-07-2006 11:11 AM |
| Loose ball screw support | cbass | General Metal Working Machines | 0 | 08-06-2006 08:01 PM |
