Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 03-05-2008, 09:57 PM
Fiero Addiction is on a distinguished road
Need help identifying this belt
I need help identifying a belt. It came from a linear stage which I believe is from a silicon wafer positioning machine. The belt is .130" pitch, .290 wide, open ended. It's some type of plastic and has two steel cables molded into the edges with 'rungs' connecting them. It runs on what appear to be roller chain sprockets. I'm looking for a source for replacement belting, or .130 pitch chain.
Jon
Old 03-06-2008, 01:07 AM
2muchstuff is on a distinguished road
Sounds like a Posi-Drive chain. http://www.sdp-si.com/D790/PDF/D790C02192.pdf
If it's not nailed down, it's mine.
If I can pry it loose, it's not nailed down.
Old 03-06-2008, 12:37 PM
Well that's the closest thing I've seen, but still not the same. The posi-drive has the wrong pitch and width unless there are other sizes that are not listed on SDP site. I'm still looking for something before I switch it over to XL or MXL belts and pulleys.
Old 03-06-2008, 01:28 PM
pixburghenat is on a distinguished road
Jon
Looks like something from smallparts.com
pix
Some of my best finds were in the trash....
Old 03-09-2008, 08:41 AM
I don't see anything that's even close on smallparts.com.
Old 03-09-2008, 11:07 AM
Lightbulb
..try http://www.pic-design.com <<<< They should have it.
belts and pulleys - no slip belt, your pitch is in there, stainless steel braided wire reinforced, no picture, you may be able to download a catalog.
enat
Last edited by pixburghenat; 03-09-2008 at 03:30 PM. Reason: I looked on the internet for the info and posted
Old 03-10-2008, 07:20 AM
Thank you, that's it!
Old 03-11-2008, 11:04 PM
I've ordered the No-slip belts from PIC-Design, they appear to be a perfect match for the ones I need to replace. I've also found that WM Berg has the same style belt, they call it Flex-E-Gear positive drive chain.
Thanks again.
Jon
Old 03-13-2008, 09:17 AM
mhasting2004 is on a distinguished road
Looks like you already have your answer. I was going to say iot looks like berg chain www.wmberg.com
Cheers
Mark
Need Sherline Belt & qestion on X2 Belt Drive? Oldboy Benchtop Machines 12 03-06-2008 12:42 AM
Need help identifying pflynnjr Stepper Motors and Drives 0 04-18-2007 11:58 AM
Belt size/spec for Sieg X3 driving belt rashid11 X3/SX3/G0619/G0463 0 02-10-2007 07:01 AM
Seeking Belt Sander Belt Source 6 x 48 Dugg General Metal Working Machines 3 12-24-2006 09:48 AM
Help identifying this please studysession General Metal Working Machines 38 12-05-2004 01:40 PM
