Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 03-04-2008, 09:24 PM
bcromwell is on a distinguished road
How to Lube Ball Screw?!?!
Two of my Ballscrew's have zirk fittings on the face of the flange, no problem to lube. The third has a 2mm hold on the side of the flange, no fitting/hole on the face. Looks new/refurb. and when I turn the screw I can hear the balls moving like there is no lube inside at all. Any chance the 2mm hold is the fill point? My "needle" tip for my grease gun is closer to 8mm so I wonder if I need a special tip/adapter. 1.5" screw fyi.
Picture show the little hole and the PITA place it is located
what bearing fit with acme screw 1/2 -10(for cheap ball screw) apex Linear and Rotary Motion 4 07-27-2007 11:15 AM
Lead screw lube amount. servo belt replacement bob1112 Linear and Rotary Motion 2 11-24-2006 06:59 PM
Ball Screw lube JOE65 Industrial Hobbies (Support forum) 2 06-06-2006 09:42 PM
New technology.... old debate.....ball screw vs lead screw trubleshtr Linear and Rotary Motion 1 08-15-2005 08:42 PM
Lube for acme screw? carlnpa DIY-CNC Router Table Machines 2 02-12-2005 08:04 PM
