Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 03-04-2008, 05:55 AM
stirling is on a distinguished road
more questions on rack n pinion
I've done the searches and can't find the specific answers to my question so...
With steppers (not servos) has anyone used direct drive and if so was it successful for your app. If so can you tell me a little about it e.g.
The application - router/mill/plasma etc.
your travel per rev
your motor torque
your achievable accel
Next: with a rack n pinion drive, is it best to accurately machine your mounting system such that the pinion is "exactly" the correct distance from the rack (pitch circle touching pitch line)? OR - is it best to make it adjustable? - your opinions much appreciated.
Ian
Old 03-04-2008, 07:05 AM
Greolt is on a distinguished road
For direct drive pinions on steppers look at Mechmate and older Shopbots.
My R&P is 4:1 reduction via timing belt and that is not what your asking for.
The only way to mesh them IMO is spring loaded.
Unless you want to go a lot more money on anti backlash pinions. Would be overkill IMO on a router or plasma.
I'm very happy with the accuracy and performance I'm getting.
Greg
Old 03-04-2008, 07:22 AM
Hi Greg - thanks.
out of interest though - whats the linear travel per motor rev?
Cheers
Ian
Old 03-04-2008, 07:31 AM
Approx 19mm
Greg
Old 03-04-2008, 07:50 AM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
You may have looked already but you can find more MechMate details at:
http://www.mechmate.com/forums/index.php
Gerald has done a lot of work sorting out R&P setup. And a lot of free plans too.
You can find a lot of the info for a R&P setup there - calculating motor/speed/etc/etc.
Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
Old 03-04-2008, 08:34 AM
Thanks greg. Just a quicky about your spring loading - doesn't that mean that as load increases, the pinion will tend to try to climb out of the rack?
Thanks Jim - I'm still working my way through the Mechmate stuff, but I think I'm getting some good new info. I'm thinking direct drive is looking good - particularly for my latest venture - plasma cutting where resolution doesn't perhaps need to be as fine as routing for example.
Cheers
Ian
Old 03-04-2008, 10:19 AM
ger21's Avatar
You need a strong enough spring to prevent it from climbing.
Old 03-04-2008, 10:29 AM
you guys are worrying me now just done a bit of looking at this and...
If you use a spring then arn't you going to mesh too close i.e. INSIDE the pitch circle/line?
Old 03-06-2008, 02:03 AM
OK - that killed it moving on...
it seems not many are using direct drive - for those using reduction of one sort or another, what travel per rev are you using and what sort of motor power? any info gratefully received.
Ian
Old 03-06-2008, 05:45 AM
Ian
I am using 4:1 toothed belt reduction
495oz steppers, two driving the gantry
Approx 19mm/motor rev
Greg
  #11   Ban this user!
Old 03-06-2008, 11:35 PM
Gerald_D is on a distinguished road
I have two productive MechMates with direct drives, (about 70mm/rev) cutting wood productively. Maybe about 2000 older shopbots with direct drive. (their "Alpha" model was direct drive for maybe 5 years?)
For a plasma cutter I can't see you needing anything finer, or being concerned about exactly where the pinion rides in the rack. (we only get concerned when the pinion wears and rides against the root of the rack).
  #12   Ban this user!
Old 03-07-2008, 02:12 AM
Thanks again Greg - useful info.
Thanks Gerald - this is the sort of stuff I need - I'm going to be using Mod1 rack and am trying to figure out what pinion. The smallest possible is 12 teeth with (being Mod1) a 12mm diam so therefore about (pi x D) 38mm travel/rev.
But I'm thinking it would be better to use a slightly larger pinion if poss which will give me more pinion/rack contact and therefore presumably less ware ergo longer life. 20 teeth for example (20mm D) gives me (pi x 20) around 63mm travel/rev but I wondered if this was too much so seeing your 70mm/rev makes me happier.
Agreed
All I was thinking here was that as I understand it pinions are designed to mesh with the rack where their pitch circles/lines meet. The way they are cut means that they CAN actually mesh closer BUT you then have reduced the diameter of the circular contact and therefore affected the travel / rev. However on second thoughts - I'm wondering if I'm talking horse ****
Ian
rack and pinion questions klick0 Linear and Rotary Motion 4 05-05-2006 05:54 PM
rack and pinion planescott Mechanical Calculations/Engineering Design 4 05-04-2006 10:48 PM
Rack and pinion TinkerDJ Linear and Rotary Motion 6 11-29-2005 11:42 PM
Rack & pinion coolman DIY-CNC Router Table Machines 3 11-30-2004 10:57 AM
calculatiing pinion size for rack and pinion setup Apples DIY-CNC Router Table Machines 3 05-18-2004 09:36 PM
