Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 02-29-2008, 04:00 PM
mobus1 is on a distinguished road
ballscrew question
hi folks,
and now, my next question of perhapes many more!
I was fortunate to aquire an ADEPT xyz setup.
nice quality servo/ballscrew drive setup.
the y axis motor mount casting is damaged beyond repair, and replacement parts are too costly.
my plan is to remove the y axis (and perhaps even the x axis) ballscrew and use it (them) in my homebuilt setup i'm starting to work on.
The ballscrew threads are a slow spiral, about 2 "threads" per 1" of shaft length. one rotation of the shaft yeilds about .875" of travel.
I can guess that with a fast moving DC servo drive, this setup must work just fine.
here is the question;
Please help me understand the relationship of the rotation speed vs. the travel distance /speed.
Will the slow spiral work ok to be driven by a stepper motor?
Will the rotation vs. motion travel distance be compatible with a stepper motor?
the ballscrew/shaft setup is so sweet, I'd sure like to use it and save some cash.
Old 02-29-2008, 04:16 PM
Al_The_Man's Avatar
That pitch is usually considered rather coarse by most CNC standards, Typically pitch of 4 or 5 is normal (.25 ~ .2"/rev).
A pitch of this nature is usually reserved for low load/low inertia applications, such as in a CNC punch where the only relatively light sheet material is the load to be moved, not the table.
With a ballscrew, the mechanical advantage increases with a decrease in pitch or an increase in diameter.
Old 02-29-2008, 05:03 PM
ger21's Avatar
Not necessarily with a router though. Our heavy machine at work uses ballscrews with about a 1" lead. And a lot of guys building routers here are starting to use 2 turn per inch acme, finding that they get much better performance. This is especially true with steppers, because they have much more power when spinning at slow rpm's. Although as Al said, the mechanical advantage is less, so you may need more powerful motors. One other issue is that you lose resolution.
Old 02-29-2008, 05:10 PM
Al_The_Man's Avatar
Originally Posted by ger21 View Post
Not necessarily with a router though. Our heavy machine at work uses ballscrews with about a 1" lead. And a lot of guys building routers here are starting to use 2 turn per inch acme, finding that they get much better performance. This is especially true with steppers, because they have much more power when spinning at slow rpm's. One other issue is that you lose resolution.
I guess I am spoilt working with servo's, also the resolution issue usually applies to steppers, as this is overcome by servo encoder resolution.
Old 02-29-2008, 05:28 PM
ger21's Avatar
I was going to point that out, but he said steppers so I didn't bother.
Old 02-29-2008, 05:37 PM
Thanks folks,
This info makes sense, the ADEPT setup was basically a pick and place application...all it was moving was the weight/mass of itself, plus a pneumatic gripper/ No a large load.
Too bad. The screws are in great shape. I was hoping to use them.
Old 02-29-2008, 09:48 PM
ger21's Avatar
Thanks folks,
I'd use them if it were me. Maybe I wasn't clear, but I don't see a problem with them, provided you have enough torque.
Old 02-29-2008, 09:58 PM
LazyMan is on a distinguished road
Another advantage of using a higher lead is you may get away with a smaller diameter ballscrew because it wont have to spin as fast. Otherwise you can easiley run into whiping issues with a long screw.
Old 03-01-2008, 06:52 AM
yes, i guess i did not understand. Seriously, I am i bit dyslexic and I have some trouble grasping written concepts. You can imagine how difficult a time i have with equiptment manuals and docoumentation.
I have learned most things by actually setting up a demo or prototype setup and then playing with it. Thats the best way for me to understand functional relationships, especially with mechanics.
So, bottom line, because of the lesser amount of grooves(threads per inch), it results in a different torque curve? Meaning the motor will tend to "lug" without a higher torque rating?
Sort of like a car trying to start from a stop in 4th gear?
Don't laugh, I sometimes need to use analogies in order to understand.
In any event, it sounds like it would be worth it for me to remove the ballscrew from the broken mount, set up a test bench with my stepper motor driving it and observe/measure results.....Yes?
thanks
by the way, since i have the servos with encoders, maybe i should look into that direction instead of steppers?
I had come across stepper drives large and small, so i just figured i would go that route...any pros and cons offered?
Are the servo drive any more expensive than stepper drives?
Since cost is an issue, I'm thinking ballscrews will cost me more than the servo drives will.
thanks
Old 03-01-2008, 07:31 AM
Oldmanandhistoy is on a distinguished road
Just wondering why no one has mentioned gearing?
John
Old 03-01-2008, 08:02 AM
ger21's Avatar
Originally Posted by Oldmanandhistoy View Post
John
If you size the motors correctly, you shouldn't need to gear it with steppers. I'd only consider gearing it if you already had the steppers, and needed a little more force.
Old 03-01-2008, 08:04 AM
ger21's Avatar
Not a different torque curve, just a different location on the curve (for the better), but less force delivered by the screw. If you don't have enough torque, it won't "lug", but it might just stall, or sort of "sputter" (lose steps).
Ballscrew/Ballnut question. alexccmeister Linear and Rotary Motion 9 07-21-2008 08:29 AM
Need Help!- Ballscrew question? Haas TM-1 CJH Haas Mills 3 01-26-2008 01:01 PM
BallScrew Question rodzilla Benchtop Machines 2 01-07-2008 09:08 PM
Ballscrew/Ballnut question lvittori Linear and Rotary Motion 5 11-06-2007 05:26 AM
Ballscrew bearing question pstockley Mechanical Calculations/Engineering Design 3 05-16-2006 04:21 PM
