| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
im having trouble visualising how you connect the servo to the drive screws and have a bearing in an "endplate" to keep it all stable, if possible could you post some pictures of this, i have searched but have found nothng to hep my design many thanks |
| most servoos run quite fast and unless your ballscrews are very low pitc you might want to consider gearing them down. A toothbelt might also solve your difficulties aligning. if not look for shaftcouplers.These are quite straightup when installing. good luck.
__________________ Finally CHIPS you can have as much as you can without the doc. complainting about your cholesterol. |
| Yes, both ends are normally support with a bearing housing, one end usually houses a thrust bearing, for coupling it should be zero backlash type, do not use bellows type for ballscrew, especially aluminum. Al.
| Servo tuning for twin screw axes... | digits | Gecko Drives | 20 | 06-30-2007 10:56 AM |
| Lead screw lube amount. servo belt replacement | bob1112 | Linear and Rotary Motion | 2 | 11-24-2006 06:59 PM |
| connecting | KrashKing405 | Open Source Controller Boards | 18 | 07-26-2006 05:30 PM |
| Wanted: V2XT servo/ball screw pullies | v488 | Bridgeport and Hardinge Mills | 2 | 10-22-2005 09:38 PM |
| z axis servo on main ball screw or down feed handle | replicapro | Benchtop Machines | 5 | 10-29-2004 10:25 PM |
