Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 02-10-2008, 01:33 PM
eloid is on a distinguished road
ballscrew preload disk
1). Im rebuilding this ballscrew....need some advice for load ballbearings
2). the attached is a picture of new orginal new ball screw, there a spacer disk between the ballnuts what proper name for this preload load disk spacer... im trying to find a replacement part... the other picture shows the unit i want to rebuilt with missing preload spacer where to order this ...what is it called?
Name:	ballscrew complete.jpg‎
ID:	52962   Click image for larger version
Name:	no preload disk.jpg‎
Old 02-11-2008, 02:45 PM
Kuroda refers to it simply as a "spacer". I suspect the spacer is fit at assembly with the screw to obtain the desired preload for that specific assembly, not necessarily interchangeable. "Custom fit" so to speak.
Dick Z
DZASTR
Old 02-11-2008, 05:40 PM
Kuroda spring
do you know anyone that sells it the cupped spacer disk that spring loaded
Old 02-11-2008, 06:26 PM
A "cupped" disc may not be a simple spacer. Some are ground to maintain a dimension that produces a preload. There is also another type of disc that is not a dimensioned spacer, but is actually a type of spring called a Bellville washer or spring.
The preload is set by drawing each of the nuts toward each other. The closer together, the higher the preload. Using this method, small pitch spacing errors are compensated for by the compliance of the spring/washer. You might want to google "Bellville spring washer".
I noticed in a Nook ballscrew catalog a double nut preloaded with a wave spring. This would function the same as a Bellville but would pobably have different physical dimensions.
Dick Z
DZASTR
Old 02-11-2008, 06:30 PM
thats excatly what im looking for, just didnt know the right name for it
http://www.reidsupply.com/detail.asp...preload%20disc
Old 02-11-2008, 07:15 PM
Mike Nash is on a distinguished road
Also check http://www.mcmaster.com for more choices. They come in inch, metric, various id/od sizes and force ratings.
Old 02-11-2008, 07:36 PM
anyone know what the preload is tyically on ballscrews
Old 02-11-2008, 08:16 PM
What is the ballscrew description? Brand name, dia., pitch, ball size etc.?
Dick Z
DZASTR
Old 02-11-2008, 08:28 PM
5/8 .2 pitch ballbearings .123" name brand dont know its a rolled ballscrew
nut stamped rc0605 ...linear set was made by lintech complete unit rails and ball screw and nut.
Old 02-12-2008, 11:32 AM
eloid, can you please see if that is the correct part number? I googled Lintech
www.lintechmotion.com products-ballscrew assemblies-r series-RS062 series. You may want to scope this out. It shows all the loads, speeds etc. The preloaded nut for RS062 is shown and mentions it as a Bellville spring/washer but does not give the preload or preload dimensions. They do give some support phone numbers.
I didn't find a RC0605. That may be a part number for that component rather than the assembly. Lintech can probably answer all your questions and supply the appropriate part.
Dick Z
DZASTR
  #11   Ban this user!
Old 02-12-2008, 05:27 PM
Dick Z
Thats the number stamped on the ball nut.. I have lintech assebly number, and have looked there... I have determined the od and the pitch, no info on vendor located on web etc they use who ever gives them the best price im told. I call them... they want me send the unit down and reburbish it for 2k no thanks.. secoundly ive modified it and extending the rails. so it will void there warranty.
preload on spindle bearing adryan General Metal Working Machines 7 06-21-2010 05:59 PM
Another which is better R&P,Ground ballscrew,rolled ballscrew,Acme,beltdrive etc.thre lgalla Linear and Rotary Motion 10 01-16-2007 11:27 AM
preload ? andy55 Linear and Rotary Motion 5 01-04-2006 06:28 PM
sherline 5400 Preload nut dneisler Benchtop Machines 1 11-28-2005 11:40 AM
strange bearing preload thread on ballscrew mxpro32 Benchtop Machines 14 03-22-2005 01:23 PM
