Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 02-07-2008, 11:15 AM
jp_dt is on a distinguished road
lead screw prep and maintenance
I think I read on dumpstercnc.com that some leadscrews can use some prepping to knock down the burrs before use with a delrin nut. Is this true for any leadscrew? If so, could anyone recommend a technique? I just ordered some precision rolled, 2 start, ACME screws from Mc Master Carr.
I'm also curious if there is a de-facto lubricant that everyone uses on these things.
Doug
Old 02-07-2008, 12:39 PM
ger21's Avatar
The screws you ordered should be pretty smooth and clean and not need anything done to them.
Belt vrs. Ball Screw vrs. Lead Screw stevesplanes Linear and Rotary Motion 7 01-09-2006 11:23 AM
New technology.... old debate.....ball screw vs lead screw trubleshtr Linear and Rotary Motion 1 08-15-2005 08:42 PM
Ball Screw or Lead Screw? Which is Better? ljoe1969 DIY-CNC Router Table Machines 4 07-28-2004 08:49 AM
Lead Screw? dmgdesigns DIY-CNC Router Table Machines 6 02-26-2004 09:32 AM
Ball Screw and Lead Screw ljoe1969 DIY-CNC Router Table Machines 9 11-21-2003 08:06 AM
