Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 02-01-2008, 05:45 PM
tuffenuff is on a distinguished road
Red face Problems Locating Lead Screw Supplier
First of all I would like to say this is the most informative forum that I have ever belonged to, I would like to say to everyone here THANKS ! Because with out the people here contributing their time and experiances with homemade, hobby or even custom CNC machines I wouldnt be the only person here lost in the woods without a compass. Enough butt kissing now LOL. I work in a scrap metal yard in NY and I have come across enough parts to build my first machine, and it works well I might add, but now I am looking for anti backlash nuts for the lead screws I have, and finding it impossible to find anything close so I am turning to anyone here that may be able to help.
My lead screws are 10 start
Major .742 approx 3/4
Minor .626 approx 5/8
6 threads per inch ( if you count 1 - 6) some say the first thread is actually 0 so it would make it a 5 thread per inch
it moves the gantry 2 full inches on 1 single revolution of the stepper motor. The leads are connected to the stepper by way of timing pulley and belt but the timing pulleys are the same exact size on the stepper and the lead screw. I hope that I have measured everything the right way, I talked to a guy fron roton.com and he said the biggest they had were 3/4 X 1.5 which is .5 to short and he said if I want the extra .5 I would have to go with a 1 inch lead screw. If anyone knows who or where I can get even regular nuts for what I have described above at least then I could make my own backlash nut design. Thanks for listening and thanks for all the information that I have obtained here.
Old 02-01-2008, 06:13 PM
SORCHEROR is on a distinguished road
are you sure it moves 2 inches for one turn?also what are the outer dimensions of the nuts you need?you must have exsisting ones now,right?and are looking for anti-backlash
you said they are 10 start,thats hard to find nuts for
Old 02-01-2008, 06:14 PM
i think you have 5 thread per inch screws,which is .200 pitch and on a 10 start would be 2 inches movement per turn,does that sound right?
Old 02-01-2008, 06:16 PM
I am positive it is 2 inches per revolution I just remeasured it. the outside diameter of the nut is 1.125 or 1 and 1/8 thanks they also have a 3 hole flange mount would you like that measurement also?
Old 02-01-2008, 06:18 PM
like I said in the first post it depends on how you count them , if you start with 0 then it is 5 threads the guy at roton told me that
Old 02-01-2008, 06:21 PM
i build routers and table top cnc's and make my own screws and nuts,but a 10 start isnt all that easy to do,your best bet it to buy one from roton and modify it to work
Old 02-01-2008, 06:25 PM
i dont remember seeing any 10 starts nuts there what would you suggest getting ? or should i go ahead and buy acme rods and backlash nuts?
Old 02-01-2008, 08:28 PM
mcwilsonmfg is on a distinguished road
try this place for the backlash nuts: www.dumpstercnc.com/leadnuts_acme.html
if that doesn't work for you I might be able to make them 4 you.
post a couple photos of the shaft from the side and the end.
Old 02-02-2008, 12:53 PM
mcwilsonmfg Here a the pictures you asked for. If you think you might be able to make the nuts I do have an extra screw I can cut a piece off of and mail it to you
ID:	52258   Click image for larger version
Old 02-02-2008, 01:09 PM
Here are some pictures with measurements sorry about the poor lighting all measurements are in inches
ID:	52260   Click image for larger version
  #11   Ban this user!
Old 02-02-2008, 01:49 PM
tuffenuff,
looks like you could use a new cover for your caliper..LOL
yea, its hard to read the numbers on your caliper.
How long is the screw you are using?
did you look up the nuts from dumpster? p/n ABL12105 $22.50/ea.
the acme screws from McMaster Carr? p/n 99030A704 1/2"-10 6' lg $55.77/ea.
Old 02-02-2008, 01:56 PM
ger21's Avatar
You're going to need to find the manufacturer to get nuts for that. Nook makes sme similar metric screws, but not the same as yours. I've seen 1" 10 start, but with a 1" lead, and I haven't seen 3/4" 10 start screws.
Problems with motor stalling due to motor/lead screw alignment Bimmerkc1 DIY-CNC Router Table Machines 3 01-24-2010 06:12 PM
help locating supplier for motor brushes bherr Bridgeport and Hardinge Mills 12 06-04-2007 12:53 PM
Lead Screw Supplier Ed Williams Linear and Rotary Motion 1 04-23-2006 07:36 AM
Ball lead screw backlash problems titchener Linear and Rotary Motion 7 09-13-2005 03:34 PM
Problems aligning motor with lead screw. SCCoupe DIY-CNC Router Table Machines 11 02-15-2005 06:33 PM
