Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 01-17-2008, 10:16 AM
Khalid's Avatar
Khalid is on a distinguished road
Unhappy HELP: RUNOUT IN BALL SCREW
I have 5/8'' -5TPI , 1300 mm (51.18 inches) long ball screw mounted on my X-axis. Currently i am getting two problems with it:
1) Whip
2) stalling of motor at two extreme locations.
I checked the ball screw and found a runout/sag in middle portion (about 4 to 5 mm).
My question:
a) Is that the ball screw run out cause its efficiency to loose and stalling the motor.?
b) How to remove the run out?
NOTE:The same size,length ball screw i installed at my Y-axis with no problem.
Sorry for bad english
Old 01-17-2008, 10:24 AM
ger21's Avatar
Sounds like it might be bent and you may need to get it straightened.
Old 01-17-2008, 10:41 AM
Khalid's Avatar
Okay i will check it..i will check it... but if its bent what may be the affect on ball screw and stepper motor?
Old 01-17-2008, 12:23 PM
mll mll is offline
mll is on a distinguished road
The travel may be to long for that size screw, I use a 20MM thick screw when traveling that distance. You are using comparable to a 16mm screw.
Old 01-17-2008, 01:04 PM
LeeWay's Avatar
LeeWay is on a distinguished road
I have the same size ball screw about the same length. I get no whip @ 300 IPM. I only have one end captured by bearings though. The other ends rides in just a plain bearing, but not held firmly. I get no binding at the ends either. It sounds like you have both bearings pulling the shaft in on itself. This will make it want to deform if that is the case. With it binding at the ends, it also sounds like yopu have either the carrier bearings or the ball nut nut in the wrong location. I suggest loosening these things up some and then jogging. If it jogs better, lock one end of the shaft down and let the other just float. You may need to shim the ball nut holder or otherwise center it on the carrier bearing end.
Kinda hard to tell just what needs to be done without seeing the details or the machine in person.
Lee
Old 01-18-2008, 02:46 AM
Khalid's Avatar
Thank you Leeway for your detail information. I will check those parameters and its gr8 to hear that the same length/size screw can attain 300IPM without trouble.
Best regards
Old 01-18-2008, 02:58 AM
Khalid's Avatar
what if the ball nut in wrong location?.. means if i installed the ball nut toward the motor side then what will happen?
Old 01-18-2008, 03:08 AM
LeeWay's Avatar
I don't think you can install a ball nut backwards. Either direction should be okay, depending on how you hardware is setup. You may gain extra travel if it's mounted one way or the other depending on the design of the mount.
It's the mount that I am referring to that may not be centered on the screw. It has to hold the nut perfectly centered throughout it's entire length of travel in order not to bind. There may be enough flex in the middle to prevent binding, so these need to be adjusted at the extremes of travel where the screw is held by the bearings. That's where you will locate the center or the sweet spot for the ball nut mount.
Lee
Old 01-18-2008, 09:56 AM
Khalid's Avatar
Thanks Leeway for your response After close inspection of my lead screw attachments I found two problems. i will solve them but again i want to learn more so asking questions:
Please answer for:
1) If my ball screw has one end bearing 1mm down (i.e. 1mm slope).. then what will happen?
2) If my gantry (z-axis hold down) is tightly fitted with interference of about 1mm (pushing the ball screw back 1mm)...then what will happen?
Old 01-18-2008, 10:30 AM
LeeWay's Avatar
I'm not sure what will happen. The closer you can set everything up to true, the better everything will work and it will last longer. Again hard to judge without seeing the machine and knowing what and how the bearings are installed. Rule of thumb. Shoot for perfect and when you get it as close to that as you can, that has to be good enough. If it's not, then you need to backtrack and maybe remake some parts until it is good enough.
Lee
  #11   Ban this user!
Old 01-19-2008, 03:12 AM
rexstep is on a distinguished road
excentricity
The OD of rolled ballscrews is always out of concentricity with the balltrack to some degree. This will also contribute to whipping. And other problems especially if you have a preloaded set-up.
Rick L.
  #12   Ban this user!
Old 01-19-2008, 06:55 AM
Khalid's Avatar
Rexstep... I dismantled the ballnut balls from screw.The balls appear 1/8" i.e. 3.175 mm. I found that no ball were missing, however it seems that the size of the balls are less. That was due to i am having some play in transverse direction in the ball nut with screw. I also found negligible backlash.
I want to install some bigger size balls in it say 3.25 or 3.3mm. Is that right?
As i have no ebay or foreign trade experience,if u please tell me from which ball bearing i can get the closer size of the balls. (I can manage to get such ball bearing here in my country to get the required size ball)
cheers
what bearing fit with acme screw 1/2 -10(for cheap ball screw) apex Linear and Rotary Motion 4 07-27-2007 11:15 AM
roller screw versus ball screw. Paraprop Linear and Rotary Motion 2 04-15-2007 04:21 AM
Belt vrs. Ball Screw vrs. Lead Screw stevesplanes Linear and Rotary Motion 7 01-09-2006 11:23 AM
New technology.... old debate.....ball screw vs lead screw trubleshtr Linear and Rotary Motion 1 08-15-2005 08:42 PM
acme screw to ball screw question Billw DIY-CNC Router Table Machines 9 07-18-2005 12:10 AM
