Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 01-07-2008, 05:32 PM
AKFALAR is on a distinguished road
Will this be an Anti-backlash ball screw system?
Will this system have problems with backlash?
Old 01-07-2008, 07:39 PM
spoiledbrat is on a distinguished road
As long as the two ballnuts are being pulled apart from one another (or pressed toward eachother), backlash can be eliminated. A truly great system is not rigid, but has more of a spring like force between the two nuts. Tension is then set as appropriate (20lbs? 70 lbs? consult the manufacturer). With the spring, the nuts are then able to "squeeze" past the tight spots (or imperfections, dust, etc) on the screw, and backlash is eliminated.
If you are going with a rigid setup like this, I think it might be cheaper just to load over sized ball-bearings into the nut, and forget the idea of two nuts.
Just my opinion,
Rob
Ball vs. Anti Backlash Acme Screws eman5oh Polls 23 03-10-2012 08:33 PM
ball screw backlash andrewbishop66 Linear and Rotary Motion 2 04-06-2007 04:03 PM
acme lead screw and phosphor bronze anti-backlash nut any advice? rhino Linear and Rotary Motion 4 05-20-2006 03:29 PM
Ball Screw Backlash rocks101 DIY-CNC Router Table Machines 2 03-04-2005 08:35 AM
Ball screw backlash options Stevie General Metal Working Machines 22 11-08-2004 11:32 AM
