| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
| What's with the 000000943 part. How you gonna measure that accurate? Let alone the 125 part which is less than half a tenth? Get real.
__________________ Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way. |
| That was a cut and paste from a mm to inch conversion program. get over it. |
| Thanks ! |
| AAMOI how did you know that you lost exactly 6. I spilled a load of balls over my desk before I even knew what a ballscrew was. I don't know if any hit the floor, but I gathered up all that I could and refitted them by using grease. They were about 1mm diameter, smaller than yours. Anyway, I screwed it back on and could not feel any axial movement so reasembled the drive. Everything works fine, but now I wonder if the grease will cause problems some time and did I get them all back in? Perhaps someone could advise? Dave |
#10
All grease is, is a medium to hold oil. The problem with grease is dust and dirt get stuck on it more readily.
#11
I did not know exactly. Luckily 100 balls of 2.381 mm cost only about 4 euro. Pleasant surprise.
Until no ball will fit. Then there will be a lot left over to play around with. |
#12
You don't want to try to match new balls in with the originals. You need to replace all of them. If you add six new balls in and they're even .0001" larger than the ones you have, only the new ones will engage the screw properly while the originals will tend to float. If they're smaller even by a tenth, there's no point in having them. -Rick L. |
| AFFECT OF MISSING BALLS IN BALL SCREW | Khalid | Machines running Mach Software | 20 | 01-02-2008 07:59 AM |
| How many balls in nut? | phantomcow2 | Linear and Rotary Motion | 10 | 04-19-2007 10:30 AM |
| detent balls | norvil1 | General Metalwork Discussion | 7 | 02-08-2007 06:51 PM |
| re-load balls screw to reduce backlash? | cncuser1 | Linear and Rotary Motion | 51 | 09-30-2006 08:08 PM |
| ball screw balls | Super-Dave | Mechanical Calculations/Engineering Design | 2 | 02-12-2005 07:46 PM |
