Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 01-04-2008, 07:48 PM
sp1nm0nkey is on a distinguished road
Alternate name for spline/screw
I'm looking for rods with both splines and threads cut into them. THK makes them under the name "screw/spline", but that's the only reference I can find to them. Any idea if there's another name for them? The idea is that by fixing the spline and screw nut, you can spin them both in the same direction to spin the rod axially, or spin just the screw to move the rod linearly.
Alternate G codes? hutchndi G-Code Programing 3 08-18-2009 04:57 AM
Alternate Lead Screw Mounting Idea Jay C Mechanical Calculations/Engineering Design 4 02-20-2005 01:32 PM
80/20 Alternate jbuskirk 80/20, TSLOTS and other Aluminum Framing Systems 1 11-04-2004 08:21 AM
Alternate Linear Rails?? ehiebert DIY-CNC Router Table Machines 12 10-02-2003 09:36 AM
Alternate Z-axis designs chuckknigh DIY-CNC Router Table Machines 4 04-29-2003 01:24 PM
