Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 01-03-2008, 05:27 PM
sp1nm0nkey is on a distinguished road
Rail profiles?
I've been ordering HSR linear motion slides off ebay for my cnc machine. However, I've gotten a few without a matching rail. Can I run THK bearings on ABBA rail?
Old 01-03-2008, 09:06 PM
TAB TAB is offline
TAB is on a distinguished road
I don't know first hand if you can do that but you might want to call SKF (they bought ABBA) or THK to see. I think they will likely say that you cannot and will probably tell you that the slides and rails are matched.
It it were me and that was their response, I would try to mount the slide on the rail regardless. There are two things that will happen.
1. The slide will not fit the rail. It may not go on at all or it may go on loose. If it goes on loose, the ball bearings could fall out so make sure you put a container below to catch them. Also the container is a good idea as if it does not fit on to the rail profile, the bearings could fall out as well.
2. the slide goes on.
if it fits you will need to determine if the fit is good enough for your application.
Good luck.
Old 01-03-2008, 09:21 PM
Zumba is on a distinguished road
It's possible but don't bet on it. Most brands are dimensionally interchangeable (overall rail + block height and bolt patterns), but the blocks and rails aren't compatible.
Old 02-04-2008, 12:11 PM
CNCAddict is on a distinguished road
Don't even bother trying to talk to THK...they're customer support is terrible. They won't even sell you end seals direct...motion industries is helping me out, but it's been 3 months and still no seals... THK sucks. They have great products, but so does everyone else....definitely go with one of the other guys if you can help it.
Grinding Cam profiles on a DeskCNC 4 axis mill Paraprop Carken Products (Deskam, DeskCNC etc) 37 05-01-2009 09:58 AM
Making your own custom endmill profiles? saturnnights General Metalwork Discussion 5 05-02-2006 08:28 PM
plasma profiles trevorhinze CNC Plasma and Waterjet Machines 12 01-24-2006 11:14 AM
Profiles for CNC lathe Don C Mini Lathe 5 04-24-2005 07:17 PM
mkautomation - wooden t-slotted profiles?!? Losos 80/20, TSLOTS and other Aluminum Framing Systems 5 02-06-2005 02:48 PM
