I snooped around the Roton site, and see a conspicuous lack of information about the accuracies of their ballscrews, but the price tells me that they are rolled thread, and probably come "backlash free", which means there is lots of backlash which they do not charge extra for
I suspect you'll need to have mounts for dual angular contact bearings custom made. The shaft mount requires more than setscrews, rather, it will require a turned shoulder on the screw and a threaded nut to capture the pair of bearings on the screw. The housing needs to be of such construction that the bearings are also firmly captured, ie, no press fits or snap retaining rings because these are unreliable end location methods.
LinkBack URL
About LinkBacks
