| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
| McMaster Carr doesn't have them I don't think. The smallest I've seen are 10mm from www.vxb.com
| what are they for? maybe you have the wrong application for the bearing? if its the end of a shaft that driving an axis on a cnc machine, then use a 10mm bearing and put a spacer in there thats 8mm id and 10 mm od. |
| Angular Contact Bearings For Spindle | Kakarott | Linear and Rotary Motion | 4 | 11-13-2007 03:18 PM |
| Taper Roller Bearings VS Angular Contact | mxtras | Linear and Rotary Motion | 26 | 10-12-2007 11:32 AM |
| Angular contact bearings | martinw | Mechanical Calculations/Engineering Design | 38 | 12-26-2006 06:35 AM |
| Will this spindle work for a small CNC mill? Not angular contact bearings... | Joel Elliott | Benchtop Machines | 1 | 04-17-2006 12:20 AM |
| Ball screws and angular contact bearings? | dowling177 | Mechanical Calculations/Engineering Design | 1 | 01-27-2005 03:21 PM |
