Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 12-15-2007, 10:56 AM
bml6116 is on a distinguished road
Question about Linear Rails Sizing
I am (trying to) building a CNC router loosely based on the MadVac design. Cutting area is 4x8 with 8" (travel) z-axis.
The gantry (y and z-axis with spindle) weighs in at about 240lbs with an overall height of 26".
So here is the question: Will 20mm linear rail (Hiwin AG20) with 4 trucks work? The trucks are mounted 22" on center, drive is rack and pinion on both rails. I.e. Will te gantry fly off if the E-stop is hit during jog? I am not concerenc about the weight, but the moment force.
I have a hard time calculating the forces involved.
Any help is greatly appreciated.
Cheers,
Bernhard
Old 12-15-2007, 11:03 AM
ger21's Avatar
Should be plenty strong.
Old 12-15-2007, 01:33 PM
Gerry,
Thank you! I was hoping for that answer. Just was a bit leary, because Hiwin calls those rails " Medium Duty".
Cheers,
Bernhard
Old 12-15-2007, 05:13 PM
svenakela is on a distinguished road
Check the specification. 650 kg per wagon is a lot of load.
http://www.hiwin.com/lg/images/agh-sa_agh-ca.gif
Old 12-15-2007, 07:57 PM
I do have the specs; my problem is that I do not know how to calculate the dynamic force and moment for my homebrew gantry.
Cheers,
Bernhard
Old 12-17-2007, 01:59 AM
I think you don't have to worry. Just make sure your parts are tight/preloaded and backlash free.
Old 12-17-2007, 12:14 PM
Thank you. Now I have 2 positive answers, soooo I am going to get the rails.
Cheers,
Bernhard
Old 12-31-2007, 05:45 AM
jimashworth is on a distinguished road
Bearing Sizeing
Cheers,
Bernhard
Bernhard,
When your looking at linear guides, they are often purchased by how strong the unit looks. In your case, the bearing in our size 20 has a load capacity of over 3,000#, which would more than meet you requirements. You could get by with something much smaller, but the ways would look small and undersized. Starting with a size 20 is a good place to start. If you think the unit will have a high cycle life, than move up to 25. To acheive longer life you move up in size. In a low cycle application, SBG20FL guide would be fine. Just one more word. When using 4 ball circuit linear guide blocks, you can often get away with using only one guide and bearing block due to the ability to take high moments. A great cost savings
Always willing to help.
Jim
Old 12-31-2007, 07:51 PM
lgalla's Avatar
lgalla is on a distinguished road
Bernhard
This is the machine I am using.The rails seem to be slightly under 25mm.I am sure you won't be building heavier than this.
Happy New Year
Larry
L GALILEO THE EPOXY SURFACE PLATE IS FLAT
Old 12-31-2007, 08:15 PM
neilw20's Avatar
neilw20 is on a distinguished road
Cool Stops?
Put energy absorbing buffers at the stops. Absorb inertia over some distance.
Either rubber, or pnuematic with blocked off outlet.
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
  #11   Ban this user!
Old 01-01-2008, 07:31 PM
Originally Posted by jimashworth View Post
Bernhard,
Jim
Jim,
Thank you for the info. I looked your website (lee linear), but couldn't get through the registration screens to get to the info. Also, -on a more general note- I wish more companies would post prices and have on-line ordering; saves both parties time and effort.
Cheers,
Bernhard
  #12   Ban this user!
Old 01-01-2008, 07:39 PM
Thanks for the tip! A mechanical stop with shock absorber is one more thing I hadn't considered, will come in handy in case of limit switch/estop/software failure.
Cheers,
Bernhard
DIY Linear Rails JerryFlyGuy Linear and Rotary Motion 77 11-29-2009 05:48 PM
Linear rails lgalla Linear and Rotary Motion 1 08-22-2006 03:48 AM
How to cut linear rails IQChallenged Linear and Rotary Motion 4 06-07-2006 06:20 AM
Linear bearing spacing & Sizing linear rails? fyffe555 DIY-CNC Router Table Machines 3 12-07-2004 01:09 PM
