Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 12-11-2007, 08:23 AM
DrStein99's Avatar
DrStein99 is on a distinguished road
supplier for linear rails
I'm looking to buy a pair of HSR-35's (or equivilant), with four bearings. These are double-contact bearings & rails with caged balls, about 7/8" square rail - Anything between 26" - 30" lengths.
Does anyone know any online suppliers / distributers? Preferably with their prices listed online or thru a catalog - I don't want to do business with a salesman over the phone, I'm just buying a pair for a prototyping project.
WWW.RAIDGEAR.NET - FFC cables, foam headset replacement parts, and other gadgets.
Old 12-11-2007, 10:14 AM
ger21's Avatar
http://www.tos-world.com/webapp/wcs/...Id=-1&msgFlg=Y
Old 12-11-2007, 07:15 PM
DrStein99's Avatar
Ok, for two rails 30" long and four bearings is about $700.
Old 12-11-2007, 07:21 PM
ger21's Avatar
Do you really need 35mm? Those are really massive. I just got a set of 25" HSR 20's on Ebay for $170. If you're not in a hurry, Ebays your best bet.
Old 12-11-2007, 07:40 PM
DrStein99's Avatar
25's will due just fine. If the costs are within a certain threshold, I would prefer the largest possible naturally.
Did you buy yours new or used from ebay?
Old 12-11-2007, 07:55 PM
ger21's Avatar
Used, but they're in great shape. I just got them today.
Old 12-11-2007, 08:04 PM
DrStein99's Avatar
I bought from ebay before some new and some used. I have a nice pair of hsr-35s which are 36" long cost me $320 about a year ago.
I will settle for used, but prefer new; unless it costs a fortune. I think I found something around 30" 2 rails, and four blocks for about $250 new.
Old 12-11-2007, 08:12 PM
ger21's Avatar
You also might want to watch this.
http://tinyurl.com/ypd7cj
Old 12-12-2007, 02:39 PM
kwms1956 is on a distinguished road
HIWIN Linear guideways
I invite you to take a look at our selection of HIWIN linear guideways at www.automation4less.com. All our pricing is online, but HIWIN requires that we make you log in to see it. That takes just a few seconds to do...and you don't have to talk to anyone. The HIWIN HG35 series has a four-row bearing design. There are some variables that I could not know that could influence things, but I priced out 4 standard HGW35CCZ0H blocks and two pieces of rail 700mm (27.58"). Total cost of those items delivered to you in the lower 48 states via ground shipping comes to $538.29. If you don't have to have slides with four-row bearings and you're not absolutely bound to the 35 size, our new venture, Automation Overstock (www.automation-overstock.com) has a great buy on some "combination packages" of a piece of rail measuring no less than 780mm and an LGW20 "flange" block for $78.10. We just bought a HUGE inventory of HIWIN's older stock (both medium [AG] and heavy [LG]) which are two-row bearings. It will be a few weeks before we get it all in our warehouse and sort it out, but we'll have sizes up to 65...and plenty of it!
Old 12-16-2007, 11:48 AM
mackeym is on a distinguished road
The HSR's u mention aren't caged. The SHS is a newer model that is. Both are available to browse and buy online through THK's online store.
http://www.tos-world.com/webapp/wcs/...11751&msgFlg=Y
I found a really good deal on ebay: two SHS20 1800mm rails 4 blocks for $350 new. If you look hard enough, you should be able to find what u want for much cheaper than the THK online store.
  #11   Ban this user!
Old 12-20-2007, 05:10 AM
rexstep is on a distinguished road
We just got stock of 20mm LM guides in a couple of weeks ago. They are heavy preload for metal working and are available in both wide and narrow carriages: www.homeshopcnc.com
-Rick
  #12   Ban this user!
Old 12-31-2007, 05:33 AM
jimashworth is on a distinguished road
Lee Linear SBS #SBG35-FL-2-K1-711-N-@ $400.00
SBC Linear Guides are top quality guides at less than the other brand. Linear guides are stocked in New Jersey. If you need a price list, just drop me a line and I'll get one emailed to you.
I made a slide using the Roller Bearing Pillow Blocks. It has to be the smoothest slide you'll ever build. It also reduced motor draw by just switching bearings. Check them out.
Jim
linear rails lgalla Linear and Rotary Motion 5 02-08-2008 04:35 PM
US supplier of THK/Abbatech style linear guides? Matty Zee DIY-CNC Router Table Machines 2 02-09-2007 07:00 AM
Linear bearing spacing & Sizing linear rails? fyffe555 DIY-CNC Router Table Machines 3 12-07-2004 01:09 PM
Linear Rails BeerFizz DIY-CNC Router Table Machines 2 11-14-2004 11:29 AM
linear rails ljoe1969 DIY-CNC Router Table Machines 7 01-07-2004 10:18 AM
