Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 11-21-2007, 01:24 PM
V8 BUG is on a distinguished road
2 steppers for x axis good or bad
I was thinking of using 2 nema 34 frame steppers for my x axis. What would be involved in the electronics end? I am ok with the mechanical part. The machine will be a moving gantry style using thk hsr25 bearings on all axis with 2 blocks per rail. I will post pics when I get some time.
Thanks for any input
Kevin
Old 11-25-2007, 07:30 AM
bluejay_ca is on a distinguished road
To have two motors sync'd together you'll need to have a drive for each.
Connect the second as if it were the "A" axis.
Some cnc programs such as Mach will have a slave option to do all the work for you(recommended), otherwise you might try to share the parallel port outputs between the two drives.
P.S. you should be in the electronics forum.
Old 11-25-2007, 12:53 PM
monte55 is on a distinguished road
I use 2 495 steppers for my X, 1 for the Y and 1 for Z, Xylotex 4 driver board
and Mach 3 and all is well. I just put a post under the DIY section w/pics. My table is 60x60" and generally runs at 60 ipm routing but will go a bit faster.
Nick
Old 11-26-2007, 06:12 AM
DistortedDesign is on a distinguished road
Check out Joes cnc 4x4 hybrid. He is running 2 drives together without using up a fourth axis and he synced them together with belts as a backup.
Old 12-09-2007, 07:59 AM
jhop2 is on a distinguished road
Monte55
What size lead screw do you use?
Old 12-09-2007, 09:54 AM
Originally Posted by jhop2 View Post
Monte55
My lead screws are 3/4 x 6tpi x about 60" on the X & Y axis. I made my own bronze nuts so I could have more than 75% thread and a lot less slop.
HCNCPRO board good for these steppers? mind_nl Hobbycnc (Products) 0 03-31-2007 04:31 PM
Are these steppers any good? BenDover Stepper Motors and Drives 1 10-09-2006 02:17 AM
Are these steppers good enough for a cnc mill??? Dre361224 Stepper Motors and Drives 7 05-20-2006 05:47 PM
Good steppers??? Dre361224 Stepper Motors and Drives 3 04-20-2006 06:00 AM
slo-syn steppers (MD091) are they any good ? belgrado Stepper Motors and Drives 9 03-20-2005 04:32 PM
