Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 11-08-2007, 05:36 PM
MoneyB is on a distinguished road
80/20 Linear Motion Bearings
Has anyone used this type of bearing to make a router? The bearing is made by 80/20 Inc. and uses UHMW instead of bearings. I'm not sure of the accuracy of this type of bearing though.
I'm fairly new to this forum and, after reading for about a month, have had a few failed attempts at making my own router. I would like to buy some 80/20 to build my table, but have been trying to decide on bearings and motors etc. I saw these on eBay and wasn't sure if they have the tight tolerances that are required with this type of build. The main use of this machine will be woodworking, but I can't say that I would never try to mill aluminum.
This is my first post by the way
Thanks in advance,
B
Old 11-08-2007, 06:34 PM
gth629e is on a distinguished road
B,
First of all welcome to the CNC router community. Now you have the CNC bug and can't get rid of it lol.
As far as the bearings go, I would strongly recommend against using these bearings. They are made for simple linear motion. It is almost impossible to build and accurate machine with these.
I bought several just to try. I am a big fan of 80/20 for structural purposes. However, if you want a decent machine I would use another linear motion setup.
The bearings slide freely enough when by themselves. However because of their limited tolerances, they tend to bind when paired.
After hours and hours of shimming and adjusting the UHMW panels, I did get them to work for a while but after a while they started binding again.
I have seen them implemented successfully, but they simply aren’t made for the kind of precise linear motion of a CNC machine.
Especially for the first machine, I would look for an alternative. It is even possible to implement other options for the same price or close to it.
If you are building a CNC router then check out the site that I am working on with my coworker Keven. www.cncroutersource.com
There is a free builder’s guide there that can help you. Although it is not all loaded yet as the site is still young.
However, we are both engineers and do offer free consultation on designs and will help with any problems as much as possible.
Anything from materials selection to helping you find the cheapest parts. We are both very active. Although, I will probably be banned for telling you about it lol,
We are not trying to keep you from these forums. In fact we encourage it.
Anyway, keep the questions coming and feel free to get some other opinions.
Brian
Brian@cncroutersource.com
Old 11-08-2007, 07:44 PM
Brian, Thanks a ton for the information. That was exactly what I was looking for, someone that has attempted to use these in a build. I wasn't too confident, but wanted someone elses opinion on them. I'll keep searching for a solution. I believe that I have looked through the site you listed and it was very inspiring and informative. Thanks again for the input.
Old 11-08-2007, 08:32 PM
B,
No problem. Keep up the research and let us know if we can help in any way. We update the website daily.
Of course, CNCzone.com is a wonderful resource as well!
I will keep up with the posts.
Brian
WWW.CNCRouterSource.com
Linear Motion FAQ Cutters Cove DIY-CNC Router Table Machines 6 09-30-2009 01:36 AM
Linear motion Sheldon Linear and Rotary Motion 3 08-14-2006 11:27 AM
skate bearings versus linear bearings paul langwade Linear and Rotary Motion 7 05-29-2006 10:06 AM
Linear motion Wez DIY-CNC Router Table Machines 11 12-07-2003 12:54 AM
Using 80/20's Linear Motion EvanRobert DIY-CNC Router Table Machines 5 07-01-2003 02:56 PM
