Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 10-25-2007, 11:44 AM
Gold Member
Rhodan is on a distinguished road
Mounting/loading leadscrew
How is this for mounting an ACME leadscrew? The bearings would be ABEC 7 skate bearings.
Both ends would be mounted the same with nylon locking nuts on the threaded portion of the shaft. Before tightening the nuts, I'd bolt on and tighten the stretcher across the uprights. Then I'd tighten the nuts to tension the leadscrew.
Exactly how much torque I still have to figure out as the skate bearings aren't going to take a lot. Probably just enough so that the kerk nuts don't groan during rapids.
Old 10-25-2007, 01:06 PM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
Cams will be along shortly to flog you into submission.....
I think your design is fine but your bearing selection is going to make or break the performance. Considering you are mounting an acme screw indicates the lack of super-duper precision, therefore I think the arrangement is perfectly acceptable. I think it would be better to use a set of AC bearings mounted DB for the thrust loading and preload but these are going to cost you more as you likely know.
Let's see how badly Cams beats you up over this, but I am voting for sticking to your plan. It looks good to me.
Scott
Consistency is a good thing....unless you're consistently an idiot.
CNC mill questions - thrust bearings, leadscrew mounting, general questions tonofsteel DIY-CNC Router Table Machines 8 02-03-2012 03:42 PM
loading ballscrew nut russell DIY-CNC Router Table Machines 18 08-03-2011 01:48 PM
Loading Limit martindugdale CNC Machining Centers 0 05-08-2007 07:06 AM
Leadscrew mounting - lengthwise movement Rhodan Linear and Rotary Motion 2 08-29-2006 12:10 PM
Acme leadscrew or Trapezoid leadscrew is better? minicnc DIY-CNC Router Table Machines 3 03-07-2005 11:57 AM
