Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 10-23-2007, 07:23 PM
Art Ransom's Avatar
Art Ransom is on a distinguished road
Mechanical advantage of lead screw
I have a guy who wants me to build a gantry. The problem I have is that the Z axis will be in the 250 lb range. If I use a 10 TPI lead screw driven by a stepper with 10:1 gearing what will my mechanical advantage be? What size motor would I need to drive Z at 50 IPM?
Old 10-23-2007, 08:06 PM
ger21's Avatar
Go to www.nookind.com and look in their acme catalog. For each of their screws, they give you how much torque is required to lift one pound. Divide this by 10 to allow for your gearing.
Old 10-23-2007, 08:31 PM
Al_The_Man's Avatar
They also have a ballscrew section, though their load calculations do not include inertia considerations due to acceleration. Depends on how fast do you want to get up to 50"/min?
Old 10-25-2007, 09:17 AM
bluejay_ca is on a distinguished road
Steppers run much better at low speeds. I have 2 800 oz/in steppers on 1/2" ballscrews with a pitch of 5/in. My gantry is made of aluminum, around 125 lbs. I microstep at 2000 p/r, or 10000 p/in. I max out at around 130 i.p.m. but that is not motor inability rather the limits of my computer. The motors stall at the exact same speed when disconnected from the screw, and the speeds were the same with one motor. The second motor was more for maintaining squareness/rigidity than increasing travel speed
Old 10-26-2007, 10:46 AM
Gold Member
Rhodan is on a distinguished road
I just found this:
http://www3.wcu.edu/~ballaaron/met36...dule8/mod8.htm
About 1/3 of the way down the page there's a stepper-leadscrew example using 250 oz/in.
My 272oz/in on a .1 pitch 1/2 ich leadscrew works out to:
272 oz/in / .25 in = 1088 oz
1088 oz / 16oz/lb = 68 lbs
68x2x3.1416x.25 / .1 = 1068 lbs
Advantage = 1068 / 68 = 15.7
ACME is roughtly 30% efficient I think (variable due to loading methods and nut types/tightness etc) so that gets knocked down to about 4.7. So I can get roughly 1278 oz/inch at the axis (6.66 ft/lbs).
At least, thats the way I read it
Lead screw who? searcue Linear and Rotary Motion 2 06-13-2006 05:02 AM
Belt vrs. Ball Screw vrs. Lead Screw stevesplanes Linear and Rotary Motion 7 01-09-2006 12:23 PM
New technology.... old debate.....ball screw vs lead screw trubleshtr Linear and Rotary Motion 1 08-15-2005 09:42 PM
Ball Screw or Lead Screw? Which is Better? ljoe1969 DIY-CNC Router Table Machines 4 07-28-2004 09:49 AM
Ball Screw and Lead Screw ljoe1969 DIY-CNC Router Table Machines 9 11-21-2003 09:06 AM
