Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 10-20-2007, 04:56 PM
Gold Member
Rhodan is on a distinguished road
How many trucks to hold Z axis?
I'm making a Y-Axis with two IKO 20mm linear rails with LWES20 trucks. At first I was planning on using four trucks (two each top and bottom) but after playing with the trucks for a while they seem really, REALLY steady. I'm thinking I might be able to use just two trucks, one per rail. Is this a bad idea?
The machine its going on uses 272oz/in steppers with a 1/2-10 leadscrew and pushes around a 2.25HP router. Do you think this would be too weak when moving along the Y axis?
Old 10-20-2007, 11:11 PM
rustamd is on a distinguished road
I think it would be more rigid with 4 trucks. The weight of a router I would think would make it bind, maybe not much but at least little bit. If you already have the trucks, might as well use them
Old 10-21-2007, 10:36 AM
Gold Member
Actually, here's a quicky rendering of what I mean
Old 10-21-2007, 11:09 AM
ger21's Avatar
You'll probably be limited to around 100ipm with that motor screw combo, so you should be OK. If you had a LOT of force on a long Z axis, you might have problems. But I wouldn't think so with what you're doing. I would suggest 1/2-8 2 start acme, though.
Old 10-24-2007, 09:41 AM
Gold Member
Ok thanks!
If one doesn't work out, I can always just drill more holes and use both.
Old 10-24-2007, 11:24 AM
digits is on a distinguished road
Have you had a look at this thread? New Machine Design book from Alexander Slocum (of Precision Machine Design)
The PDF's on machine design are excellent reading
Using 4 trucks, which is what just about everyone does is actually overconstraining the design - 3 trucks is in theory optimal! As you say though, those linear rails are amazingly tough - I would have a look at the data sheets to decide whether or not the trucks can take it. You will probably find you have a massive saftey factor with just two trucks though.
Old 10-25-2007, 03:58 AM
svenakela is on a distinguished road
I have a friend who's routing solid oak with a deWalt router mounted on one THK 25 rail with one truck.
Old 10-25-2007, 12:37 PM
Gold Member
Lol, solid oak!
They do seem really solid. Can't get it to wiggle at all in any direction.
I guess what I really have to worry about is the mounting plate deforming due to torque on the rail. I have 4 x 3/8ths aluminium on there now and I can't imagine plunging with enough force to twist that aluminium - I only have 272oz-in motors with kerk nuts. I think I'd stall long before the aluminium deformed.
Old 10-26-2007, 07:45 AM
Lol, solid oak!
If you're driving with screws, you have to remember to multiply up the torque by roughly 2PI/pitch (which doesn't take into account the screw efficiency) to get the motor force - my motors produce about 3.5Nm peak, but my 5mm pitch ballscrews boost that by 1250x to 4400N of force - enough to lift 440kg/900lb! It can literally bend a 80x80mm (3" square) aluminium extrusion with out any drama on my 35mm HiWin blocks/rails - it also bent a 50mm wide, 20mm thick (2"x3/4") aluminium plate like it wasn't there! Don't worry about your rails, worry about what you bolt them to!
Old 10-26-2007, 12:35 PM
unterhaus is on a distinguished road
I was thinking about this since I got some nice rails with only one truck each for my z axis. I was thinking about offsetting them a little. These are wide rails, so I probably could use one rail.
Vacuum hold-downs and rotational problem about the z axis cpcp Work Fixtures and Hold-Down Solutions 5 12-08-2006 08:02 AM
rc 4x4 trucks tnc Parts for Radio Control Models 1 11-19-2006 05:47 PM
Axis move during feed hold 1ctoolfool Haas Mills 3 09-12-2006 11:12 AM
What size rails for these Bearing trucks planekrazie Linear and Rotary Motion 16 09-04-2006 10:02 PM
Bearing Trucks camcam Linear and Rotary Motion 9 06-16-2006 04:08 AM
