| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
Hi folks, if i go shopping on ebay for complete linear slides to try to make a mill with the least machining and individual parts sourcing how much of an issue is it if the units gearing is not the same ? You see what would make a complete axis so simply but the chances of you getting an idential ballscrew/complete slide any time soon are minimal. I've read several cnc on a budget articles and if your building an ideal machine you'd make steps/distance on each axis identical, however other than this factor some of the ebay surplus looks very tempting. How much of the software you guys use allows different travel/pulse on each axis ? Didn't know what forum, probable software cure to hardware problem. I want to end up 4 Axis milling organic sculptures so i don't realy need super accuracy but it would be nice ...and if i had to i could stretch the model by certain percentages to compensate, but thats such a sloppy solution Cheers |
| Practically all software will allow individual ratio/scaling. It is done all the time in the CNC Machine world. One thing I would look out for in linear ballscrew slides, is to go with the smaller lead screws as opposed to hi-lead that are in the order of .5"/turn and above. Al.
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| thancks for reply,is that just because they'd need much beefier motors and not so applicable if slide already has one mounted? Is there a too fine pitch at the other end of scale,like impractically slow,there were some realy cheep assemblys the other day but not ball scew and pitch looked a bit fine,not fragile,just lots of tpi. they'd been in a power recline medical chair. if i built something big it (i'm in 2 minds at moment) may only need to cut foam,although wood or plastic might be handy also ross |
| That tends to bring it back to a practical resolution. Direct, the high lead ball screws require lower inertia motors for high accel. rates etc. Al.
| Another stupid question? | t305100 | General CNC (Mill and Lathe) Control Software (NC) | 15 | 09-03-2006 09:01 PM |
| Stupid Question | CNCRob | CNCzone Club House | 2 | 09-04-2005 02:42 PM |
| stupid question | boomer187um | Autodesk Software (Autocad, Inventor etc) | 3 | 08-29-2005 05:16 PM |
| New here, 1st stupid question! | FXRocket | General Metal Working Machines | 4 | 11-03-2004 10:04 PM |
| STupid newbie question..... | sentra52 | DIY-CNC Router Table Machines | 2 | 03-05-2004 12:20 AM |
