Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 10-04-2007, 08:18 AM
bearwen is on a distinguished road
Belt or Rack
I have a question I am looking at building a 4" X 8" cutting area router 8020 or steel I will cut wood, Foam signs commercial types and some aluminum sheet goods thin stock for signs and maybe some aluminum blocks prototype stuff and parts and well I have the design the weights roughlly and the motors etc the big question I have is should I run rack and pinion ala shopbot or should I run a continuose belt system I need speed but accuracy is important within .005" or less.
Bearwen
Old 10-07-2007, 12:04 AM
ahren's Avatar
ahren is on a distinguished road
Both of these are good options for speed and large work envelopes. However, accuracy can be a problem, as rack and pinion can be plagued by backlash, while belts can stretch somewhat. If it weren't for your desire to make aluminum blocks, I would recommend the belt drive system, since you can keep the motors that move your gantry fixed. However, rack and pinion will likely yield a more rigid drive system.
Done carefully, either of these solutions can meet your needs. However, for ruggedness, I would go with the rack and pinion. Spring load the pinion into the rack to get rid of backlash as much as possible, or go with a helical rack (more $$$).
Ahren
www.cncrouterparts.com
Timing belt as a rack? jacampb2 Linear and Rotary Motion 6 09-25-2007 08:21 PM
Belt Drive vs Rack & Pinion babinda01 Linear and Rotary Motion 4 05-08-2007 07:36 PM
Ball screw, Timing belt or Rack and pinion abomination Linear and Rotary Motion 10 04-30-2007 11:14 PM
Belt size/spec for Sieg X3 driving belt rashid11 X3/SX3/G0619/G0463 0 02-10-2007 08:01 AM
Anyone blown up a Rack/pinion? Belt Drives? JerryFlyGuy Linear and Rotary Motion 9 01-06-2006 08:20 PM
