Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 09-25-2007, 08:29 PM
martinw is on a distinguished road
Z axis linear bearings for MDF router
This may be in the wrong thread. If so apologises.
Plenty of MDF framed routers use pipe and skateboard bearings for the Z axis travel. This seems to work well.
Very few of the MDF framed constructors use linear bearings like these for their Z axis..
http://www.vxb.com/page/bearings/PRO...Systems/kit995
Now, I can see that dust might be a problem without some means of preventing it getting in, unlike the skateboard way which is "self cleaning", but, apart from that, is there a reason for not using them?
I'm curious, and any opinions are very welcome,
Best wishes,
Martin
Old 09-25-2007, 08:45 PM
ger21's Avatar
Alignment can be tricky, but I used them on mine, and although I haven't cut anything yet, they seem to work great.
http://www.cnczone.com/forums/attach...3&d=1136858794
http://www.cnczone.com/forums/attach...4&d=1136859518
Old 09-25-2007, 09:06 PM
Oldmanandhistoy is on a distinguished road
Hi Martin,
I used them on a plywood machine for over a year and had no problems. The dust was taken care of by the wipers and I did not use lubricant. The only reason I stopped using them was because I built a bigger machine and used linear rails and blocks for more rigidity. To align them accurately I made a ply template and a hand router.
John
Old 09-25-2007, 09:14 PM
Dear Gerry.
I think your craftmenship is in a completely different league compared to mine!
I'm talking wonky drill-press, "bodge it with filler" stuff here. Maybe a bit better on a good day....
BTW, that is a great looking machine.
Thanks for the advice,
Best wishes,
Martin
Old 09-25-2007, 09:22 PM
Originally Posted by Oldmanandhistoy View Post
Hi Martin,
John
Dear John,
Thank-you for that.
I'm glad that I'm not alone in thinking of trying it on a timber/MDF gizmo.
Best wishes,
Martin
Old 09-26-2007, 09:13 AM
ger21's Avatar
Originally Posted by martinw View Post
Dear Gerry.
All the holes for the rails and bearings were drilled on a standard drill press. Double face tape the parts together and use a fence to keep everything aligned.
Old 09-26-2007, 11:05 AM
Dear Gerry,
Thanks for that. Could you tell me what the shaft spacing is? It looks about 6 1/2".
Best wishes
Martin
Old 09-26-2007, 11:18 AM
ger21's Avatar
Dear Gerry,
Best wishes
Martin
I can check tonight, but 6 1/2 is pretty close. If I recall correctly, the plates on top are about 8" wide.
Old 09-26-2007, 03:06 PM
anoel's Avatar
anoel is on a distinguished road
I used them for all of the axis on my cnc router...
I would not recommend unsupported bearings on any axis greater than 12" And really a Z axis is ok because the load is usually static or within an very restricted amount of movenment.
So for the Z I give them a thumbs up... X&Y greater than 12" a big thumbs down unless you went with grossly large rails...
Nathan
Old 09-26-2007, 05:07 PM
Dear Nathan,
I was only thinking about using 20mm dia. shafts and linear bearings for the Z axis. The shafts might be about 15 inches long between their top and bottom mounting plates. The sliding carriage that would take the spindle might be about 8-10 inches tall , and the linear bearings themselves would, to a certain extent, reduce the tendency of the shafts to bend. I have not done the deflection calculations yet, but my guess is that the two shafts would not deflect by very much. I will check.
Best wishes
Martin
  #11   Ban this user!
Old 09-26-2007, 07:44 PM
Dear Nathan,
Thanks.
Sorry for asking people more questions..
If you put a single 20mm dia. shaft, 15" long, on its side and put a 45 lb load at mid span, I think the deflection of the shaft would be about 0.3 thou inches. I'm not sure why I chose 45lb.
There are two shafts, and the spindle slide to some extent will reduce deflection because the linear bearings help keep the shaft straight. My guess is that the flexure of the MDF to which the shafts and spindle slide are mounted may be the weaker components.
I'm scratching my head about the actual forces involved. Common sense would suggest that the shafts do not have to take any great vertical loads as a column, but the bending loads will depend on cutter forces, and also the lever arm distance from the spindle to the shafts. Obviously it is a very good idea to keep the spindle to shaft distance as short as possible.
Has anybody got any idea what lateral cutter forces might be for non-aggressive cuts in MDF for a small Joe 2006 type machine? OK.. not a very well framed question... (and probably impossible to answer).
Best wishes
Martin
Old 09-26-2007, 07:53 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
with 20 mm shaft i highly doubt you have anything to worry about ,
for the z on my last setup i had 1/2 ss stock and brass bushings that i made and it worked like a charm
homemade linear bearings for a 48"x96" router luther DIY-CNC Router Table Machines 6 06-27-2007 11:08 PM
homemade linear bearings for a 48"x96" router luther Mechanical Calculations/Engineering Design 0 06-25-2007 10:35 PM
skate bearings versus linear bearings paul langwade Linear and Rotary Motion 7 05-29-2006 11:06 AM
Linear slides for z axis router kent chasson Linear and Rotary Motion 4 10-26-2005 01:17 AM
Linear Bearings for CNC Router CNCMP DIY-CNC Router Table Machines 7 01-04-2005 06:09 PM
