| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
I just got this ball screw from an eBay auction: http://cgi.ebay.com/ws/eBayISAPI.dll...MEWN:IT&ih=017 I'm going to use this for my z-axis. My question is how can I turn the shaft down to install bearings? I see that some guys say that the shaft is too hard to machine. What I was thinking of doing is turning the shaft and using a grinding stone on a dremel and than using a file or fine sandpaper to get a tight fit (I do not have access to a lathe). It seems like there should be a better way to do this, but I haven't been able to find any. |
| OK here's another idea. Can I take a piece of round stock and tap the center with an acme tap and then use this as a collar? It could be secured with Loctite and a set screw? Something similiar to the Acme coupling that is made by DumpsterCNC. |
| Hey. Centering might be tough if you don't have the facilities to do it right. But it might work well enough to get you up and running. You can also try a stock pipe with the right ID/OD and simply slide it over. Don't forget that it needs to be coupled somehow to the driving motor and those couplers are usually smaller ID than the OD of such sleeve. When I had to install my machine's screws I used that excuse to buy a cheap chinatown lathe ($600). Then I used that one to build a bench. And that one to buy cabinets.... etc. You know where I'm going. My wife swears all of those things are connected to each other and they wouldn't work without everything else. buah!!! JR |
| what bearing fit with acme screw 1/2 -10(for cheap ball screw) | apex | Linear and Rotary Motion | 4 | 07-27-2007 12:15 PM |
| Attaching cylindrical open bearings? | boblon | Linear and Rotary Motion | 5 | 02-26-2007 11:07 AM |
| installing ball screw bearings | dgalaxy | Bridgeport and Hardinge Mills | 12 | 09-01-2006 10:06 AM |
| New technology.... old debate.....ball screw vs lead screw | trubleshtr | Linear and Rotary Motion | 1 | 08-15-2005 09:42 PM |
| Ball screw without bearings? | Halfnutz | General Metalwork Discussion | 6 | 06-13-2005 04:10 PM |
