| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
I'm going to be needing some clamps for XL timing belts. I don't mean the kind of clamp that clamps the two ends of the belt together. I mean a clamp that will attach the belt to the moving part of the machine. Been looking online, but haven't really found anything. Any ideas where to find such a thing? Thanks, Neil |
| Is this what you need? They can be mounted to the axis machine base. https://sdp-si.com/eStore/Group.ASP?GroupID=987 https://sdp-si.com
__________________ Wayne Hill www.codemangler.com |
| Thanks, Wayne. I had seen those clamps at SDP/SI, but it looks as though they would require me to make a hole in the belt for the screw to pass through. I'd rather leave the belt intact if possible. Also, my belts are 10mm wide, and I think SDP/SI doesn't have a clamp that wide. |
For belt patterns that are the same tooth and cog, you can cut a piece of matching belt several inches long to bridge the connection between the ends of the belt. If you are using a continuous belt, place the cut belt on the continuous belt so it cogs. Then bolt a flat plate over top of the overlapped pieces to secure it to your machine. Bolt the flat plate down tight enough to secure the drive belt. Presto!!! |
| Cheers, Samak |
| What is a timing belt and pulley ? | ynneb | FAQ of CNC Machine building | 2 | 02-18-2011 07:38 AM |
| A New Series of 16 Timing Belt Clamps from SDP/SI | carolpratt | Product Announcements & Manufacturer News | 2 | 12-27-2006 03:41 PM |
| Seeking Belt Sander Belt Source 6 x 48 | Dugg | General Metal Working Machines | 3 | 12-24-2006 10:48 AM |
| Timing belt reduction, which to use? | phantomcow2 | Mechanical Calculations/Engineering Design | 3 | 12-30-2005 12:19 AM |
| timing belt reduction | drwc | Benchtop Machines | 6 | 05-23-2005 04:31 PM |
