Results 1 to 5 of 5
Thread: Source for timing pulleys larger then 72 teeth
    Gold Member
    Sep 2004
    Hi
    I need to change my X axis reduction to 4.7:1. The ratio works out
    to a 72 and a 15 tooth HTD timing pulley. I`m wondering if the pulley
    is too small to bore out to 1/2 for my servo shaft. Also..I`ll take a
    guess that there isn`t much tooth engagment with a 15 tooth. It seems
    the HTD series only goes to 72 teeth. Does someone know of a source
    for a different class of timing pulley that goes higher then 72 teeth.
    Barry
    Jan 2007
    Hamilton,Oh
    http://www.mcmaster.com/
    worth checking
    Feb 2008
    China
    HTD 8M-30
    part code: 80-8M-30
    number of teeth: 80
    Type:6W
    Mat: CAST IRON
    Dp:203.72
    De:202.35
    Dm:100
    F:38
    L:48
    d:15
    for more information contact with jane_novo@hotmail.com
    Mar 2007
    Here is an outfit that has HTD pulleys up to 192 grooves, might have what you want.
    http://www.wyko.co.uk/pulleys/htd_pulley.asp
    Larry
    Apr 2007
    If you need a very high gear reduction, it might be worthwhile to consider a worm gear arrangement. boston gear.
    1. i want to cut timing pulleys , so help !!
      By max_imum2000 in forum General Metalwork Discussion
      Last Post: 08-08-2008, 01:16 PM
    2. Timing Belts and Pulleys
      By Gorillakilla in forum Mechanical Calculations/Engineering Design
      Last Post: 03-12-2006, 12:19 PM
    3. What pulleys and timing belts do I buy from sdp-si???
      By Apples in forum Mechanical Calculations/Engineering Design
      Last Post: 12-05-2005, 06:06 AM
    4. Timing Pulleys
      By h_2_o in forum Benchtop Machines
      Last Post: 02-02-2005, 11:26 PM
    5. Cheap Source for Timing Belts and Pulleys?
      By samualt in forum DIY CNC Router Table Machines
      Last Post: 09-10-2004, 07:41 AM
