Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 08-31-2007, 02:16 PM
dex918 is on a distinguished road
Ideal length of linear rails for Z axis
Hi, I am in the middle of gathering parts for my home made fixed gantry cnc mill.
At the momment, I have 2 pcs of 25" 20mm rails with 2 slider blocks on each rails. I plan to use this for the table axis (X axis). I still need to find 4 more rails for Y & Z axis. I have the Y axis length in mind at 18". The question is, what is the ideal length should I choose for the Z axis? 12"? 10"? or 8"?
Also, If I use a long slider blocks (92.4mm long with ratings of 1900kgF Dynamic (C) and 3330kgF (Static (C0)), how many sloder blocks should I use on each rails for the Y axis? I will use 2 rails for the Y axis too.The rails width is 20mm.
Thanks in advance.
Dexter
Linear Rails for the Z Axis Bird_E Industrial Hobbies (Support forum) 24 08-31-2007 02:45 PM
Need some Linear Rails for Z-Axis ViperTX Linear and Rotary Motion 3 09-20-2005 11:29 PM
Max length of linear rod? MrBean DIY-CNC Router Table Machines 3 03-05-2005 09:47 PM
Orientation for linear rails on X Axis Mr.Chips DIY-CNC Router Table Machines 8 12-18-2004 03:48 PM
Linear bearing spacing & Sizing linear rails? fyffe555 DIY-CNC Router Table Machines 3 12-07-2004 02:09 PM
