Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 08-20-2007, 11:20 PM
margni74 is on a distinguished road
calculating a rough estimate for bearing dynamic/static load
I've read through the FAQs and can't seem to figure out how to calculate the static and dynamic load that my bearing assembly might experience. There are various calculators on the web, but I have NO idea how to figure out the various values. <= me
Here is the situation.. i've got a turned ballscrew, I have a ~17mm length of diameter 8mm, onto which I want to sandwich 2 angular contact bearings housed in a bearing block.
The problem is, I can find only one supplier that has bearings of this ID, which is alpinebearing. The static/dynamic load rating is 220/560 lbs, or 270/706. Wow, sounds like a decent amount?
Well maybe not, just for kicks I looked at their "Ball screw support" bearing ratings for the 17mm ID unit. the rating on those: 5600/5600. Furthermore, SKF has single AC bearings of 10mm ID with a static load rating of 11.2kN, which is around 2500lbs.
Any advice/suggestions? (other than to go back to school and study mechanical engineering)
newbie Quest. Basic Static Load on Linear Bearing Block kNewton ? Calico Linear and Rotary Motion 4 06-27-2007 07:10 PM
RFQ/estimate question turmite Employment Opportunity 8 09-01-2006 06:33 PM
static & dynamic load ? mdreitzusa Mechanical Calculations/Engineering Design 17 12-13-2005 06:03 AM
Calculating series load resistors whateg01 Stepper Motors and Drives 49 12-03-2005 11:28 AM
What is "dynamic load"? georgebarr DIY-CNC Router Table Machines 3 12-03-2005 11:10 AM
