Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 08-10-2007, 05:54 AM
M100's Avatar
M100 is on a distinguished road
Question Position of thrust bearings on ballscrew
I'm converting an X3 mill to CNC and have been doing a bit of brainstorming which has thrown up the following query:
I'll be driving my ballscrews with stepper motors coupled via oldham type couplings.
I need to incorporate some thrust arrangement, preferably a pair of angular contact ball bearings configured back to back - but I don't want to increase the overhang at the drive end any more than absolutely necessary as the steppers are pretty large components.
Is mounting the thrust bearings at the non drive end of the ballscrew a bad idea?
Old 08-10-2007, 10:35 AM
*Registered User*
Glacern is on a distinguished road
Yes.
Thermal expansion will put axial stress on the motor and bearings. Keep them on the same side.
Old 08-10-2007, 11:39 AM
M100's Avatar
I know that is the conventional approach but the reason I ask is that If my calculations are right, 500mm of ballscrew raised from 20 to 60 deg C gives a total expansion of around 0.25mm in the worst case - assuming there is no rise in temperature of the ballscrew mounting i.e. the mill table / Y axis structure is held at 20 deg.
(the coefficient of expansion of mild steel at around room temperatures being 11.1 µm/m -°C, rising to 17.3 for stainless)
I can easily allow for end float in the oldham coupling of twice that without compromising the integrity of the coupling.
Old 08-10-2007, 12:25 PM
*Registered User*
You are correct, there should be no problem at all with that particular coupling.
For some reason, I had a picture in my mind that an Oldham coupling was similar to a rigid coupling rather than a lovejoy coupling.
Replacing thrust bearings yourself? SRT Mike General Metal Working Machines 4 09-27-2006 06:26 PM
Needle thrust bearings cncuser1 Mechanical Calculations/Engineering Design 6 09-18-2006 07:13 AM
Thrust Bearings chas DIY-CNC Router Table Machines 19 08-05-2004 07:07 PM
Thrust bearings CactusChip General Metal Working Machines 8 12-26-2003 01:37 AM
Thrust Bearings ToyMaker DIY-CNC Router Table Machines 2 07-07-2003 12:24 AM
