Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 08-09-2007, 01:49 PM
mackeym is on a distinguished road
Question Lathe spindle bearings and spindle material
For lathe spindle bearings, i know it's common to use two angular contact bearings on the far left, and a plain bronze taper bearing on the right. I was thinking about spreading the angular contact bearings apart to both ends of the headstock (while keeping a back-to-back arrangement and preload) and eliminating the bronze bearing. Is there any obvious reason why this would be problematic or inaccurate?
Bearings: ABEC 1 with 40 degree contact angle
For the spindle, i'm thinking about making it out of mild 1080 steel. If a plain bronze taper bearing is used, is 1080 steel compatible in terms of wear with the bronze bearing. Does anyone know what spindles are typically made out of (hardened and ground steel?)?
Old 08-11-2007, 11:53 AM
toastydeath is on a distinguished road
This isn't going to really help your situation, but some of the highest quality spindles are made of high-nickel alloys. Very low thermal expansion, and tremendous wear capacity. They are nitrided at low temperatures (for hardness), then slowly stabilized.
These spindles are incredibly stable over a very, very long period of time, and they really limit the effects of thermal instability.
Spindle material h3ndrix General Metal Working Machines 17 06-08-2010 01:18 PM
45mm ID lathe spindle bearings/rollers help! nicad General Metal Working Machines 12 10-29-2006 07:42 PM
Custom lathe spindle material? tdpyro Mechanical Calculations/Engineering Design 22 09-29-2006 01:11 PM
Correlating material/spindle/bit to speed and depth sploo Commercial CNC Wood Routers 0 04-03-2006 09:07 AM
Need Spindle Bearings for CMS Lathe esphobby General Metal Working Machines 1 08-16-2005 09:12 AM
