| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
| tuning is the answer to this. any motor should be tuned before it can optimally perform in any given situation. Though from what i've read tunign motors can be quite a challenge to a noob like meself.From here on i can only imagine what issues go along with tuning 2 motors and drives to both eachother and a axe. Your drive/motor supplier should be able to inform you about tuning procedures for your hardware. I'ld suggest a bigger motor and belting it to both screws wich will result in a synced system even when losing steps etc...... have fun !
__________________ Finally CHIPS you can have as much as you can without the doc. complainting about your cholesterol. |
| If you use mach3 for control, it will keep the motors synced with it's slaving option.
| Any risks to the drivers in trying this? This sure would be the best way to go to prevent racking. |
| Without a mechanical connection between the screws, everytime I had to hit E-stop, the unbalanced mass of the axis allowed it to skew slightly as it slid to a violent stop. This then required re-alignment which was tedious. Poweroff was also a problem as I had twin screws on my vertical axis! During running however, I did have two screws running with only electronic syncing (common step/direction pins) at several hundred IPM with no issues. |
| Single vs Dual Lead Screws | Cold Fusion | DIY-CNC Router Table Machines | 5 | 03-08-2009 05:26 PM |
| Belt vrs. Ball Screw vrs. Lead Screw | stevesplanes | Linear and Rotary Motion | 7 | 01-09-2006 12:23 PM |
| New technology.... old debate.....ball screw vs lead screw | trubleshtr | Linear and Rotary Motion | 1 | 08-15-2005 09:42 PM |
| Rotating Nut Ball Screw for dual X axis | AeroKam | DIY-CNC Router Table Machines | 2 | 08-10-2005 12:05 AM |
| Dual Screw Axis | thielert | DIY-CNC Router Table Machines | 9 | 11-25-2003 11:57 AM |
