Page 1 of 2 12 LastLast
Results 1 to 12 of 16
Thread: where can i find cheap linear motion parts?
    Jul 2007
    canada
    I have a hard time finding cheap shaft, pillow and bearing. Is there any chinese parts? Is there a U.S. or canadian manufacturer that is selling cheap?
    I wanna build the best CNC router possible and i can't get used to pipe and roller skate bearing design.....
    Is there any other solution then linear motion?
    Thanks for your help
    Francois
    Mar 2003
    Shelby Twp, MI....USA
    Jan 2007
    Cheap Linear Slides
    Jan 2007
    May 2005
    MDF? $35 sounds pretty bad for MDF. $3.50, maybe.
    Jul 2007
    canada
    35$ is for a complete axis assembly, but it still MDF....
    I'm glad they offer the same axis assembly in plastic/aluminum mix and complete aluminum for 50% and 70$, now that's cheap
    Thank you guys for your help, if you still have some cheap part source, please reply....
    Francois
    Jan 2007
    For $15 more he sells a plastic-and-aluminum version and for double that you can get the all-aluminum version. It also has the screw, bearings and mounts built-in. If you can find a cheaper already-put-together hobbyist linear slide you can hook a motor to, I'd love to hear about it. (No, used parts on eBay don't count.)
    Registered ahren's Avatar
    Feb 2004
    I sell a set of parts intended to mount to 8020 aluminum extrusion from my website. Right now, I only have the motor mounts and screw bearings, but I am working on a linear bearing solution as well. Also, my site currently only shows NEMA 23 mounts, but I should receive NEMA 34 mounts that work with the same system sometime next week. Feel free to check it out if interested: www.cncrouterparts.com.
    Thanks,
    Ahren
    ckm
    ckm is offline
    Too many projects
    Jun 2006
    Keling
    Keling has linear slides for pretty cheap. http://www.kelinginc.net/SlideBlock.html
    60" x 20mm for $41 and the bushing is $6.
    Linear rail is roughly $1 per cm, with blocks around $45....
    Chris.
    List of parts sources for CNC builders - http://www.CNCsources.net
    Dyna Mechtronics 4400C Conversion - CNC bed mill w/toolchanger to Mach3 conversion - http://www.cnczone.com/forums/showthread.php?t=50787
    Registered lgalla's Avatar
    Jul 2006
    canada
    Thanks Jerry for the VBX.
    They have 20mm round rail with aluminum support rails,50"with 2 blocks for $149.00.Sorry don't know how to read the load ratings.Dynamic con 882.Static 1370.Larken uses round rail and claims .oo1.At this price my project and other members machines may get built sooner at these prices.Perhaps Jerry could fill us in on the plus or minus on this type of rails.
    Larry
    Attached Thumbnails Attached Thumbnails where can i find cheap linear motion parts?-sbr3.jpg
    L GALILEO THE EPOXY SURFACE PLATE IS FLAT
    Aug 2007
    Hello from a keen CNC noob!
    Have any of you looked at these?
    http://www.rolloncorp.com/products/x_rail/index.shtml
    They look pretty good, have an eccentric to remove slop, and have huge torque ratings.
    I have to consider all options, here in Australia everything costs a small fortune!
    Jul 2007
    canada
    thank you i've just order the rollon corp pricelist and catalogue. Their linear system look very nice. I hope tjey're not too expensive, if they do Athreo CNC is the way to go!!!
  • Page 1 of 2 12 LastLast
    1. linear motion parts in ontario canada?
      By elninio in forum Linear and Rotary Motion
      Last Post: 07-29-2007, 08:25 AM
    2. Where can a guy find cheap mil-spec connectors?
      By damae in forum Servo Motors and Drives
      Last Post: 07-30-2005, 11:32 PM
    3. Can you compare this two linear motion parts
      By bunalmis in forum DIY CNC Router Table Machines
      Last Post: 07-14-2005, 05:53 PM
    4. where to buy online motion parts for cheap
      By hpghost in forum DIY CNC Router Table Machines
      Last Post: 03-31-2005, 04:09 PM
    5. Linear motion
      By Wez in forum DIY CNC Router Table Machines
      Last Post: 12-07-2003, 01:54 AM
