Apex, you can use 1/2" radial ball bearings for ACME 1/2-10. You also want some sort of thrust bearings to keep the screw from moving laterally. Check out my website for a way to do this without machining the ends of the rod, www.cncrouterparts.com. If you are interested, you can order parts and have them sent to me, and I can send a single shipment to you in Canada to avoid high freight costs.
Thanks,
Ahren
LinkBack URL
About LinkBacks
