| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
#13
| THX guys i was starting to believe my question must've been TOO stupid to answer. i see some very nice arguments in there some new and some i had already considered thx for that. The last thing i would love to have a opinion about is if it would be wise to use 2 of these 20mm lead per turn to move the 50kg Z-axis or should one be able to take the load with no more then normal wear and tear. i'm sure it helps to know that i'll be using lineair guides so the guides will supply for very little friction making the z-axis completely dependent of the ballscrew to support its weight. Digits sure supplied for some class A reading material in that mori seiki link. Some very good explanations in there accompanied by some very nice porn uhh.. i meant pictures. THX alot guys.
__________________ Finally CHIPS you can have as much as you can without the doc. complainting about your cholesterol. Last edited by ironDigit; 08-03-2007 at 07:40 AM. Reason: forgot to mention the lineair guides |
#14
Zumba, I'd agree if you said putting a single screw through the centre of gravity of the moving object - when you are pushing something like an X-axis with a heavy head somewhere unknown along it, the COG may be nowhere near the centre of the axis. With one screw on either end, the off-centre mass doesn't tend to cause the axis to want to rotate. Yes, ofcourse, you can build your carriage stiffly enough to constrain out the tendency to rotate - but do you want to waste strength and stiffness fighting unbalanced forces that you could simply balance by pushing on each end? Would you really shunt a railway carriage on one corner? As for your one bigger screw being better, you'd know more about that than me, but for a CNC machine, wouldn't the reduced rotational inertia of two smaller screws count for anything? Cheers. |
#15
Cheers. |
#16
| Currently, I'd say they have a lot to answer for at the moment - they inspired me to use twin screws, but there is a lot of fiddling required to get all working. Cheers, and good luck! |
| Another which is better R&P,Ground ballscrew,rolled ballscrew,Acme,beltdrive etc.thre | lgalla | Linear and Rotary Motion | 10 | 01-16-2007 11:27 AM |
| Dual Vee Wheels | Rypper | DIY-CNC Router Table Machines | 3 | 10-11-2006 05:36 PM |
| Dual Leadscrews with one Driver | rweatherly | DIY-CNC Router Table Machines | 12 | 02-15-2006 06:56 AM |
| Dual toroid transformers | green127045 | General Electronics Discussion | 4 | 06-29-2005 08:16 PM |
| dual x axis leadscrews? | bobleecnc | Mechanical Calculations/Engineering Design | 1 | 03-18-2005 03:18 PM |
