Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 07-13-2007, 03:59 PM
bridgecity is on a distinguished road
New, heavier spindle...a problem?
Please forgive a double post, I just noticed this forum and it seemed more applicable than the one I posted in previously.
I have a small (20" X 14") CNC Crafter router. It is very well built running 4 to 1 ball screws with delrin (?) nuts with 300oz/in steppers. Up until now I have had a Porter Cable 690 router as a spindle, and I have seen this CNC machine with Porter Cable 7518 3.25hp routers (12 pounds in weight) mounted on them successfully. I just bought a real 1.3hp spindle to put on it (not a router) and it weighs an unexpected 16 pounds. I have a concern about the weight on the Z stepper and whether the X and Y steppers will be able to deal with the extra weight. I don't think the mounting or the bearings will have any problem.
Any input will be appreciated.
Donn
Old 07-15-2007, 01:23 AM
Not even a wild*** guess?
Donn
Old 07-18-2007, 02:26 AM
svenakela is on a distinguished road
I don't think it's a problem. The problem would be rigidity when you start to push it, but that will be noticeable.
Old 07-18-2007, 12:03 PM
Well, thanks for the input.
To update, I've mounted the spindle and fortunately my small cnc is very rigid so there is no problem in that regard. I ran a test file and it seemed to move just fine, though the Z seemed to make working noises a little different than usual. I eased the ramping on all axis a little out of precaution.
My main concern at this point is the delrin nut on the z wearing out faster and whether I should mount a spring counterbalance on the z assembly to ease the pressure on the nut and Z stepper.
Anyway, thanks again!
Donn
Old 07-19-2007, 11:09 AM
ironDigit is on a distinguished road
a counterbalance would be quite logical if you think the weight is to much for the Z.
i'ld advise a gasspring instead of hanging a big block of weight on the back for inertia reasons/issues.if for example your Z-assembly weighs 20pounds install a 10pound gasspring but never a 20pound gasspring.
hmmm...Delr9n nuts on a ballscrew ? probably you got a trapezium leadscrew with delrinnuts or just steel nuts on a steel ballscrew.If its the steel ones you shouldn't worry too much as long as you keep it properly lubricated.if delrin i can imagine the nut wearing "faster"but i have no experience with delrin at all.
take alook at the benchtop mills cause these seem to use the counterweight most of all and there should be lots o info tehre if this didnt answer your question.
help! X3 spindle problem bcnc Syil Products 44 05-06-2008 01:48 PM
Spindle Problem - Help! bcnc Syil Products 5 05-03-2007 02:49 PM
spindle problem with tnc 151 PRIOR666 Bridgeport and Hardinge Mills 7 05-02-2007 10:45 AM
Mitsubishi spindle problem wcopley Mazak, Mitsubishi, Mazatrol 16 11-08-2006 08:06 AM
Spindle problem? GalaticDan Mechanical Calculations/Engineering Design 2 09-20-2005 06:55 PM
