Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 07-11-2007, 05:02 PM
pbunnstf is on a distinguished road
THK HSR30 Rails
I just received a nice looking set of 680 MM THK HSR30 rails and slides (4) that I bought on EBAY. I have never seen or used these before and am trying to determine their condition.
When I move the slides, they run fairly smooth but there is sometimes a small bind felt as they slide. This is when there is no pressure at all on the slide - when they are slighlty loaded with hand pressure, the slide is smooth.
Can anyone tell me if this is normal or do I have a problem?
Old 07-11-2007, 05:15 PM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
Brand new bearings have almost a notchy feel when simply pushed. When loaded, they typically smooth out.
If these are used, they cold have been subjected to just about anything. Is the bind felt shortly after changing direction or is it in the same spot everytime? If it's noticable at direction change, this is normal - it's the balls changing direction in the recirculation channels. If the bind is in the same spot each time or has a noticable pattern, it could be mechanical damage caused by impact.
I think in this case, you have to evaluate the cleanliness and determine whether the bind could be contamination also. Flush them out (if they are used) with a mild solvent - possibly pull the seals (be careful) and see whats behind them. Then purge with light oil while moving them to see if lubrication changes the feel.
Scott
Consistency is a good thing....unless you're consistently an idiot.
Old 07-11-2007, 07:06 PM
Scott,
Thanks for the info. It is at the direction change when they feel bumpy. If you press down with just a little presure, they are smooth. They look like new condition.
Gantry rails alexis221 Linear and Rotary Motion 8 03-03-2007 10:10 PM
Design of plasma table, high rails or low rails? Apples CNC Plasma and Waterjet Machines 3 12-18-2006 03:21 PM
THK rails wakeboard DIY-CNC Router Table Machines 2 01-21-2004 05:13 PM
Anybody seen or used these rails xairflyer DIY-CNC Router Table Machines 4 01-20-2004 04:20 AM
Can I Cut THK Rails? samualt DIY-CNC Router Table Machines 5 09-15-2003 05:45 PM
