Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 06-29-2007, 01:24 PM
pbunnstf is on a distinguished road
Machining ACME rod
I have some ENCO 1/2 -10 ACME rod that I need to turn down the ends for bearings. Is this easily machined in a lathe or is it hardened?
Old 06-29-2007, 05:36 PM
Eurisko is on a distinguished road
I made the mistake of ordering 2 acme rods from Enco.
They were both packed in the same cardboard tube, with no packing material to keep them from bumping together during the long UPS ride...
I can safely say that they are not hardened, judging from the burrs and dings.
An easy test is to run a file over the end of the rod.
If it can be filed easily, it can be machined easily.
Old 06-29-2007, 08:05 PM
Yes - Mine came is two seperate tubes and rattled all the way to my address.
I have not found ENCO to be the brightest supplier on several other ocasions.
B/S Acme R&P lgalla Linear and Rotary Motion 1 04-15-2007 12:57 PM
Acme Internal Thread 1 ½ - 0.250P-2.000L-ACME-2G-LH (8 START) Help pandiyan.innova CNCzone Club House 7 11-16-2006 06:47 AM
Machining anodized parts or anodize after machining? SRT Mike General Metalwork Discussion 4 03-12-2006 12:22 AM
Ab Acme Nut??? MMT CNC Plasma and Waterjet Machines 0 02-27-2005 09:53 PM
what acme tap do I need for the Enco ACME rod? AJ_Mac2001 DIY-CNC Router Table Machines 15 03-08-2004 08:24 AM
