Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 06-15-2007, 11:10 AM
3Dsigns is on a distinguished road
round vs square guides
Between round and square rails; which is the most accurate and durable?
Also, those supported round rails with the open trucks. Do those tend to get loose with time?
Old 06-15-2007, 03:07 PM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
1) Both rails should be the same, as far as accuracy & durability.
2) Supporting the round rail towards the middle of the rail is the biggest challenge (rail flex), on the square rails (THK, etc...) they can be adjusted with a simple shim. With round rails you could make a simple diy mounting block, bore a hole & just insert the bearings (sleeve).
Mounting block Round Rail:
http://www.vxb.com/Merchant2/graphic...1/kit659-1.jpg
Mounting block Square Rail:
http://torchmate.com/overview/slide4.jpg
Old 06-15-2007, 04:18 PM
Thanks Switcher!
Old 06-15-2007, 04:31 PM
Switcher's Avatar
Moderator
Also, I would never buy a THK style rail that doesn't already have the matching trucks with it (you might have a hard time finding a match later on).
Old 06-17-2007, 12:46 AM
walter's Avatar
Gold Member
walter is on a distinguished road
"GK" is the symbol for blocks and rails ordered separately. You can find "GK" blocks on Ebay, add store bought "GK" rails and they will match perfectly.
Old 06-17-2007, 02:34 AM
Zumba is on a distinguished road
Round rails have a cheapness advantage. They send them through a centerless grinder the way you'd send wood through a planer. The blocks are also cheap to make. Extrude a big long piece and chop it into small blocks. Then shove in the bearings. The bearings alone are ridiculously cheap. A large supplier can get em for under a dollar a piece (20mm).
However, for a CNC, you wanted supported rails. Add in the cost of the T-shaped support, drilling, and tapping, and the cost savings are gone. You also get dismal load capacity and very tall profile (no good).
So in conclusion, there really is zero benefit to using round rails. If you're building a low accuracy hot wire foam cutter, different story. For a router, the square rails can't be beat.
Linear guides canadamaxxer CNC Plasma and Waterjet Machines 0 11-30-2006 01:32 PM
Which is better, round or square rails? digits General Metal Working Machines 5 11-13-2006 07:09 AM
Linear bearings - round or square? kerino Linear and Rotary Motion 5 02-24-2006 09:56 AM
HARBOR FREIGHT small round column mill to a square column conversion. motomitch1 Vertical Mill, Lathe Project Log 25 12-01-2005 11:24 AM
guides and slides bean7795 DIY-CNC Router Table Machines 2 04-11-2004 09:24 PM
