Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 06-14-2007, 12:09 PM
3Dsigns is on a distinguished road
Rusty Rails
I have two 60''x1"x1" rails which were allowed to get wet and they have surface rust. Could these rails be used if sandblasted with baking soda or fine sand?
I cant find any model numbers or manufacturer on them either. How hard would it be to find bearing blocks for them?
Thanks!
Old 06-14-2007, 12:32 PM
under-dog is on a distinguished road
Try this out
I would think that the methods you mentioned may effect the surface too much.
This I believe will "kill" or "nuetralize" the rust
http://www.frets.com/FRETSPages/Mach...stremoval.html
Or you could use some oil and real fine steel wool
Old 06-14-2007, 12:37 PM
svenakela is on a distinguished road
Steel wool is the way to go. I've done it and they work really good afterwards.
Try to clean the blocks as good as possible too.
Regards,
Sven
Old 06-14-2007, 12:41 PM
Hey!
That's pretty cool!
I'll try it on a smaller piece of rail first before hunting down a vat long enough to accomodate the rails. At the price of new rails, it's worth a try.
Old 06-14-2007, 12:43 PM
Regards,
Sven
Thanks!
I'll do that too.
Old 06-14-2007, 01:24 PM
Now THAT's pretty slick!!
It worked like a charm. Tried it with a piece of galvanized pipe on the positive side, and nothing happened. The I grabbed peice of stainless and used that. It immediately began to boil around the peice of stainless, then on the rail.
Turned it black, then the rust just fell off with the steel wool.
Now to find a vat to hols those 5' rails.
Thanks guys.
Old 06-15-2007, 01:26 PM
Mike Nash is on a distinguished road
It's a bad idea to use chrome or stainless. The resultant soup is toxic per my web searches on this process. It cannot be disposed of legally in the USA very easily. Do a search on -> "electrolytic rust removal" chromate
Old 06-15-2007, 01:31 PM
WOW!
It did make the stainless piece considerably brighter
Thanks for the warning.
Won't do that again.
Old 06-28-2007, 03:39 PM
bigbunny5's Avatar
bigbunny5 is on a distinguished road
Steel wool is good idea, but I found that no matter how well you clean after using steel wool there is always some small bit lurking around to ensue Hilarity. I like to use "Scotch Brite" Green with my own special mix of Gun Oil and Auto Trans Fluid 50/50 doesn't leave scratches, but you might think about washing the oil off with Lacquer Thinner.
Design of plasma table, high rails or low rails? Apples CNC Plasma and Waterjet Machines 3 12-18-2006 03:21 PM
rusty geometry bdrmachine General Metalwork Discussion 1 07-16-2006 04:34 PM
Rusty Compressor Advice Please. ImanCarrot Safety Zone 6 04-04-2006 12:46 PM
THK rails wakeboard DIY-CNC Router Table Machines 2 01-21-2004 05:13 PM
Can I Cut THK Rails? samualt DIY-CNC Router Table Machines 5 09-15-2003 05:45 PM
