Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 06-13-2007, 12:01 AM
walter's Avatar
Gold Member
walter is on a distinguished road
Arrow THK rail plugs
I phoned THK about these little plastic plugs- here's the info if anyone needs it.
These are called C-Caps and marked according to bolt size. Example:
HSR15 rail- M4 bolt- C4 cap
HSR20 rail- M5 bolt- C5 cap
The prices are about $0.16 for C4 and $0.33 for C5 (per cap).
Unfortunately, they don't sell them direct, not even from their online TOS store. When you go through dealer (like Technico):
C4 cap $0.25
C5 cap $0.50
Old 06-13-2007, 12:06 AM
lgalla's Avatar
lgalla is on a distinguished road
Finally a THK part I can afford without E-Bay.
Larry
L GALILEO THE EPOXY SURFACE PLATE IS FLAT
Old 06-23-2007, 12:53 PM
walter's Avatar
Gold Member
Here's the picture.
_
Name:	THK C Caps.jpg‎
Mil Spec or Cannon plugs - is there an alternative? mxtras General Electronics Discussion 12 03-14-2009 05:26 AM
brz bearing w/graphite plugs rubino2112 General Material Machining Solutions 2 11-26-2006 12:52 PM
rail plugs mechanicer DIY-CNC Router Table Machines 0 01-23-2006 12:12 PM
Motor Connector Plugs rcazwillis Xylotex 5 05-11-2005 07:30 PM
large 4x8 router for cutting foam boat plugs waterboy DIY-CNC Router Table Machines 15 02-09-2005 09:59 AM
