Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 06-12-2007, 01:34 PM
ewest is on a distinguished road
Monster Router Update..
You may remember from a few months ago, I was planning on building a big router. Well, time to ice down the ol' credit cards, parts are coming in next week!
Details are this:
2 x 3 x 1 meter work envelope
THK 30mm SHS rails all around
THK 50mm Diameter ball screws on all three axes, all with rotating ball nuts.
2 sealed, caged ball bearing blocks on each rail
Steel frame, bolted, not welded
4x6" rectangle tube, quarter inch wall
3x4" rectangle wall, 5/16 inch wall
Total mass looks to be in the 3000 lb range, minus servos and table top. Thanks to the people who gave me the advice of "Figure out the weight before you size your servos! They're heavier than you think!" I'm always building stuff, but this one really shocked me - almost 500 lbs for the gantry!
Here's MY big piece of advice to all of you who have a big, expensive project in mind..
CHECK DIFFERENT DISTRIBUTORS FOR YOUR LINEAR COMPONENTS!!!
Even if they all come from the same manufacturer, the cost differences can be HUGE!
Example, one place quoted me $1920 for a SINGLE 3 meter long, 30mm rail with one block, with 10 weeks shipped from Japan.
The next place quoted me $570 for the exact same rail, and $240 for TWO blocks.... ships from Ohio, IN A WEEK.
All told, going to a different distributor saved me over $4000 and NINE WEEKS. Thank you Kaman! (serving New York City)
Also, for anybody wanting to build a good, small machine, the http://www.tos-world.com/ website is pretty good, plus it illustrates a pretty good point... which surprised the hell out of me...Using a rotating ball nut is CHEAPER than using a fixed nut and rotating screw when you factor in the expense of using two proper bearing blocks at each end of the rotating screw PLUS your regular ball nut.
Old 06-12-2007, 03:31 PM
Zumba is on a distinguished road
Good work on the pricing. Good choice of components as well. What'd you pay for the ballscrews and nuts?
Old 06-12-2007, 03:43 PM
NC_jimbo is on a distinguished road
Would love to see the details of your design.
Such as dual drive or single on lthe 2m/3m axis's?
I assume servos instead of steppers?
Ballscrew/nuts P/Ns?
How do you handle thermal expansion on screws at their ends?
Drawings?
Old 06-12-2007, 03:45 PM
Prices of the parts are as follows:
50mm rotating ball nut - $682 Each
3 meter rolled ball screw - $1415 each (I bought two)
( I think a 4 meter screw was only about $1700 and change)
SHS30 - 30 mm rail prices as follows
1 Meter - Each $195
2 Meter - Each $390
3 Meter, - Each $575
Pre-loaded block, sealed, standard length caged ball for 30 mm rail, each $110
Pre-loaded block, sealed, long length caged ball for 30 mm rail, each $120
I'm using the long blocks on the X and Y, and the standard for the Z. Each rail has two blocks on it.
Andy
Old 06-12-2007, 03:55 PM
Man I sure hope you do a build log.
Are you paying someone to build it or doing it yourself?
Old 06-13-2007, 07:40 AM
I do plan on doing a build log, but right now, I'm just concerned with finalizing the cut list so I can get the 3000 lbs and 40' long sections of steel out of the courtyard at the shop.... and between working, life, and debugging the nixie clock my girlfriend is building... well time is just at a premium.
And for the second question, YES I AM building it myself. My good friend has a metal shop in the same building, so I'll be using him and his tools to do the steel fabrication, plus he's got the mill and the lathe and CNC plasma, and anything I need to have CNC milled I can get done as a favor at another place too. I have a background in industrial automation, so while this is a big daunting project, I do know that I can see it through.
I'll throw up a link as soon as I have something.
Andy
Old 06-13-2007, 07:52 AM
epineh is on a distinguished road
We will need pics of that beast
Did I read correctly that you want 1 metre of Z travel ?
Russell
Old 06-13-2007, 07:59 AM
You're correct, I do WANT 1 meter of Z, but I can't have it :-) My components are only that long! Ideally, I would have more ceiling space too. I'll tell you though, with a bolted setup, I can always drop another few thousand and hook up taller gantry sections and a longer Z. In an ideal world, I'd have enough Z to throw an entire block of GeoFoam on the machine. Right now, I think I'd have trouble even getting a block of it in my shop!
Andy
Old 06-13-2007, 12:09 PM
walter's Avatar
Gold Member
walter is on a distinguished road
Thumbs up
Great thread!
Old 06-14-2007, 08:26 AM
mugabe is on a distinguished road
imho, very good point. It is especially important for long axis where screw is vibrating due to its weight and length.
And less inertia for the motor to handle .
Thanks.
  #11   Ban this user!
Old 06-20-2007, 12:37 PM
Good news - an 18-wheeler just pulled up to my shop, and unloaded two long, skinny crates...FULL OF BALL SCREWS AND LINEAR RAILS!! WHOOO!!
Will send pictures! I'm also working on the build-log web site.
Will post a link soon as well.
Andy
  #12   Ban this user!
Old 06-20-2007, 04:33 PM
harryn is on a distinguished road
I may need to re-think part of my project. Those rail / carrige prices are substantially cheaper than the probably lesser components I was planning to use.
Homemade CNC Router table update monte55 DIY-CNC Router Table Machines 3 03-02-2007 06:02 PM
Thanks Dave! (S4 Monster) David Bord SprutCAM 3 11-15-2006 04:39 AM
Bohner & Koehle Monster Mill? Stuff-Builder General Metal Working Machines 1 03-28-2006 03:56 PM
Update for my router. MonoNeuron DIY-CNC Router Table Machines 3 02-02-2005 06:09 AM
My Router - NEW PICTURE UPDATE ! ninewgt DIY-CNC Router Table Machines 13 08-18-2003 06:51 PM
