Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 05-20-2007, 05:18 PM
justCNCit is on a distinguished road
Getting ready to put it together. .
Heres the plan:
1/2 - 10 ACME PRESICION Threaded rod from Reid Tools.
- https://reidecom.reidtool.com/xephr/...ID_PDF_DISPLAY
-4140 hardened tool steel.
-Model AR-23, 6' long rod.
-$45.84
+2 of same thing, 3 foot lengths for X and Z axis.
1/2 - 10 ACME Threaded nut, from DumpsterCNC.com
- http://www.dumpstercnc.com/leadnuts_acme.html
- $15.00 each
+2 of same thing, X and Z axis.
1/2 - 10 ACME Threaded shaft/motor coupler.
- http://www.dumpstercnc.com/acme_couplers.html
- $15.75 each
+2 of same thing, three motors total.
AND, the key components: (these will lock around the thrust/radial bearing setup as linked right after this).
1/2 - 10 ACME Thread Clamps
- http://www.dumpstercnc.com/thread_clamps.html
- $7.50 each
Anti backlash system:
http://www.cnczone.com/forums/showth...t=34704&page=2
to be supplied by Ahren: Bearing block, motor mounts, and part # for thrust & radial bearings.
What do you think?
edit: this is meant to be a fairly cheap gantry setup, my first machine ever. I just think it reasonable to gain fair accuracy out of the setup, within a couple thou or less backlash.
297oz steppers off of xylotex, prolly.
Old 05-21-2007, 07:51 PM
Ok, maybe I'll just start buying this stuff to see if it works how I expect.
Old 05-26-2007, 11:09 PM
is this what I want
http://www.use-enco.com/CGI/INPDFF?P...MITEM=990-4042
lovejoy coupler combo, top of page.
edit: my mistake probably just use straight couplers instead.
Old 06-10-2007, 03:20 AM
The most time consuming part of this job is in dealing with shipping. The logistics are crazy. Rhino came in with $60 in brokerage. Xylotex controllers came in with $50 in brokerage.
Gonna try source it through the local shops/co's. If they can't then I'll take the risk of shipping via standard postal service. Jeez! 3 weeks of this.
Old 06-13-2007, 12:35 AM
ahren's Avatar
ahren is on a distinguished road
I think you've got the right idea! I'll be updating my website tomorrow with a recommended parts list -- I added an exploded view drawing and some general descriptions for the 8020 axes. Hopefully that will help with your design. And I'm happy to ship to Canada via USPS. I just added international shipping options to my page, so feel free to order.
Ahren
www.cncrouterparts.com
Ready for deletion jsage Test Forum 0 03-24-2007 04:16 AM
Cnc Ready 3 In 1 Machine fastlanecafe Product Announcements & Manufacturer News 0 07-21-2006 01:17 PM
Getting ready to cut landart DIY-CNC Router Table Machines 3 08-27-2005 10:10 AM
ready to take the plunge! gv71 Gecko Drives 1 11-16-2004 06:07 PM
ready to take the plunge! gv71 Servo Drives 0 11-09-2004 02:01 AM
