Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 05-08-2007, 03:41 AM
babinda01 is on a distinguished road
Belt Drive vs Rack & Pinion
I am building a CNC router about 4Meters x 1.5Meters.
I am thinking of using a toothed belt type of system as opposed to a rack and pinion system. I am wanting to use an open belt system, with the belt fixed at one end then passing around an idler, pinion and then another idler and then fixed at the other end as well(Omega drive). Has anyone used this type of system for a router? Any thoughts?
Regards
Andrew
Old 05-08-2007, 04:00 AM
paulC is on a distinguished road
Search for some of ynneb's posts he has built one and offered advice on other belt builds.
Apples built a very nice one.
Strange that they are Aussies too. Seems a popular concept down here.
Here is my thread on the subject
http://www.cnczone.com/forums/showthread.php?t=13905
Paul
Old 05-08-2007, 04:16 AM
Greolt is on a distinguished road
G'day Andrew. Still raining up there? Babinda has the highest rainfall in Australia I believe.
I thought about a belt system like you are describing.
When I priced all the pulleys, idlers, belts and anchor points I decided against it. Cheaper in the US of coarse.
You will still need to do a belt and pulleys reduction or gearbox. And still need to drive both sides of the X.
A drive shaft accross the gantry is possible, tying both sides together.
All belts stretch. Some more than others naturaly. Four meters is a lot of length. This is where it will show up.
I went with R&P with a belt reduction. I did so with reservations that I would be happy with the result. I am happy.
With the size of machine you are considering, definately look at the Mechmate. Even if only to get ideas.
http://www.mechmate.com/index.html
Keep us informed of what you decide and good luck
Greg
Old 05-08-2007, 08:12 AM
Thanks for the info guys.
Greg, where did you get your rack and pinions from??
Regards
Andrew
PS Yes it is raining at the moment Greg.
Old 05-08-2007, 06:36 PM
Andrew
I got them from TEA Transmisions http://www.tea.net.au/
They have Italian brand Chiaravalli
There is a company in Melbourne that produces it but they were expensive.
The size is "Module 1". I think you can get 1 or 2 metre lengths
I used 24 tooth pinion driven via a 4 to1 belt reduction. Best not to go smaller than 20 teeth
As I said I am very happy with the performance of the R&P so far.
Mechmate, EZrouter, Shopbot and others use it
Can you tell I am a fan of this type of drive.
I guess that if I had gone with belts I would be recomending them instead.
Greg
Direct drive with stepper on rack and pinion. jerryrigge Linear and Rotary Motion 24 10-09-2007 09:21 PM
Ball screw, Timing belt or Rack and pinion abomination Linear and Rotary Motion 10 04-30-2007 10:14 PM
Anyone blown up a Rack/pinion? Belt Drives? JerryFlyGuy Linear and Rotary Motion 9 01-06-2006 07:20 PM
What rack and pinion for direct drive to use. Apples Linear and Rotary Motion 5 08-10-2005 05:40 AM
calculatiing pinion size for rack and pinion setup Apples DIY-CNC Router Table Machines 3 05-18-2004 09:36 PM
