Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 05-01-2007, 06:32 AM
technomage's Avatar
technomage is on a distinguished road
Unhappy lead screw whip ? bearing to use and why?
Preventing lead screw whip ?What bearing to use and why?
What bearings are recomended for pretensioning my 1/2 8 2 Start x 60" leadscrew to minimize whip.
From what I have read in posts angular contact bearings are the way to go.
But all the angular contact bearings I have been able to find online are either metric or megabucks.
I know that Joe of "Joes Machine" and others have used standard radial bearings with a moderate preload and are getting resonable life out of them.
In looking I found these would one of them be better suited in terms of preload etc.
http://www1.mscdirect.com/CGI/NNSRIT?PMAKA=03379823
http://www1.mscdirect.com/CGI/NNSRIT?PMAKA=03380607
http://www1.mscdirect.com/CGI/NNSRIT?PMAKA=03379831
the machine should be sturdy enough to hold up to a hefty preload if needed
Thanks for any input.
Old 05-01-2007, 11:49 AM
You might want to search "whip" on the CNCzone search.
DZASTR
sdantonio's Avatar
sdantonio is on a distinguished road
Try looking at these, you just need to look for ones with 1/2ID
http://www.vxb.com/Merchant2/merchan...Category_Code=
If you cut it to small you can always nail another piece on the end, but if you cut it to big... then what the hell you gonna do?
Steven
Old 05-01-2007, 11:52 AM
sdantonio's Avatar
Also check out
http://www.cnccookbook.com/CCCookbook.htm
Eliminating Backlash parts 1&2, this will tell you a lot about AC bearings.
Steven
Old 05-01-2007, 04:48 PM
technomage's Avatar
I still am only coming up with metrics for angular contacts I had browsed Vxb and others for 1/2" ID bearings before posting. Am I missing something?
Ps. Thanks for Cookbook link an extra reference source never hurts
Old 05-07-2007, 03:32 PM
technomage's Avatar
Since I can't find any resonable priced 1/2" angular contact bearings I will most likely go with a "deep grove Bearing" Any Feedback on how well they hold up with axial preloading ? I belive that they are used on "Joe's Machine"?
Old 05-07-2007, 04:29 PM
Whats "resonably priced"? Equal quality deep groove radial bearings ain't cheap either. Deep groove radial bearings have SOME axial thrust capacity but preloading might cause excessive wear. NC Cams had a pretty good explanation some time ago on another thread. BTW, if your using 1/2" thread, won't you have to turn the ends down to fit bearings? I don't think you will want to locate on the thread OD. Try Peer or AST for low priced Chinese bearings.
DZASTR
Old 05-07-2007, 06:16 PM
martinw is on a distinguished road
Lead screw whip
Dear technomage,
I'm no expert on this, but I did go through the design loop that you are going through now about a year ago. My gadget is, still conceptual... I'm ashamed to say.
1) Keep the screw in tension?
If you want to reduce whip, you can do a number of things, and putting the screw in tension is one of them. The problem is that, without an extremely rigid and thermally stable frame, the screw is unlikely to remain in tension at all times. To avoid this, tension might need to be applied to the screw by a really powerful compression spring. This may put a considerable axial load on the bearings at each end of the screw, certainly more than the axial load that you might wish to apply to a deep row radial bearing.
OK, instead of using standard bearings, you could use angular contacts, but I still doubt that you could maintain sufficient tension, and at reasonable cost, as the frame distorts thermally.
2) Increase the end fixity of the screw?
Another way of reducing the tendency to whip is to reduce the "effective length" of the screw by ensuring that the screw is " positionally and angularly restrained" by the bearing arrangements at each end. You can do this by using a pair of bearings at each end. Space each bearing apart by about two bearing ODs (I think... can't find the reference..sorry).
I opted for a couple of double-row AC bearings at the motor end , and a couple of standard radials at the far end. The motor end DRAC bearings should have a couple of nuts on the leadscrew to pre-tension the inner rings of the two bearings against each other. This should prevent any axial loads , (and movement) being transmitted to the motor.
At the other end of the screw, the screw is free to move axially through the inner rings of the standard bearings. The bearings at this end do not attempt to prevent axial movement. The main span of the lead screw is not under tension.
3) Does it work?
Dunno guys...all comments welcome...
Best wishes
Martin
How to mount lead screw inside a bearing? CuttersCov DIY-CNC Router Table Machines 24 08-13-2011 07:25 AM
Belt vrs. Ball Screw vrs. Lead Screw stevesplanes Linear and Rotary Motion 7 01-09-2006 11:23 AM
New technology.... old debate.....ball screw vs lead screw trubleshtr Linear and Rotary Motion 1 08-15-2005 08:42 PM
Lead screw whip spalm DIY-CNC Router Table Machines 3 05-24-2005 02:04 PM
Ball Screw and Lead Screw ljoe1969 DIY-CNC Router Table Machines 9 11-21-2003 08:06 AM
