Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 04-27-2007, 09:02 AM
jimluu is on a distinguished road
How to straigthen ball screw
I've bought a couple of 80 inch x 1.5 inch rolled ball screws from ebay. I've just finish sanding all the surface rust off of it. Although the screws are new, they've been in storage for a long time. There is some sag in the middle, probably around .25 inch. Is there an easy way to straighten this out?
Old 04-27-2007, 10:11 AM
sanjiv is on a distinguished road
it is slightly difficult but can be experimented. please make two V blocks from wood & keep the screw on these blocks. Push manually on the bended portion so that it may slightly straighten. you also can straighten the same on press on which spindles are straightend
roller screw versus ball screw. Paraprop Linear and Rotary Motion 2 04-15-2007 04:21 AM
Big Ball Screw & Ball Nut mistake. Jack F General Metal Working Machines 12 04-28-2006 10:53 PM
Belt vrs. Ball Screw vrs. Lead Screw stevesplanes Linear and Rotary Motion 7 01-09-2006 11:23 AM
New technology.... old debate.....ball screw vs lead screw trubleshtr Linear and Rotary Motion 1 08-15-2005 08:42 PM
acme screw to ball screw question Billw DIY-CNC Router Table Machines 9 07-18-2005 12:10 AM
